Author Topic: Ms362, increasing oil output.  (Read 1235 times)
Offline PartTimeJack
« on: November 28, 2017, 07:55:14 PM »
I just purchased a 362 and have been running it for a few hours felling a couple elms. Runs great with the 20" bar, but noticed it wasn't putting enough bar oil out for my liking, even for a 20" and opened up all the way. If I was to switch to a 25" I don't know if it would be putting out enough.
Anyone have experience with a 25" bar on this saw, and oiling.
Thanks!
Just a Farmer learnin to be a Jack.
Offline drobertson
Re: Ms362, increasing oil output.
« Reply #1 on: November 28, 2017, 08:37:43 PM »
yep, I found that running winter grade oil all the time works the best, there is not much adjustment on the oil flow, but a (looser) oil works for me,, I have been running the Itasco winter grade brand, keep in mind I dont' run the saw that much,
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #2 on: November 28, 2017, 09:00:16 PM »
I've found with my 362 that the tractor supply oil has a higher volume output then the Stihl orange jug. I have a 25" bar also and it still doesn't really keep the chain wet, but it doesn't have smoke rolling off it either.
« Reply #3 on: November 28, 2017, 09:06:43 PM »
Thanks for the replies, I've been contemplating giving the winter grade a try. Has anyone ever heard of changing the oiler out for one off of something like a 440 or 660.
« Reply #4 on: November 28, 2017, 11:17:48 PM »
Yes but it was from a ms 461, only problem is you have the ability to empty the oil tank far sooner then your gas.
LT35HD Best 1 day output
Started by thechknhwk on Sawmills and Milling
Last post August 01, 2013, 07:36:20 PM
by thechknhwk
Offbearers and output question
Started by landscraper on Sawmills and Milling
Last post May 16, 2014, 12:37:19 PM
by Peter Drouin
660 high output oiler
Started by tlbrooks on Chainsaws
Last post October 02, 2015, 10:23:49 AM
by tlbrooks
Calculating dehumidifier output and MC loss
Started by GeneWengert-WoodDoc on Drying and Processing
Last post September 19, 2019, 05:51:12 PM
