Author Topic: Building stuff knowledge i don't seem to have  (Read 3318 times)
Offline 711ac
Re: Building stuff knowledge i don't seem to have
« Reply #20 on: December 22, 2017, 08:01:18 PM »
Bracing the poles and beams is going to be the trick both in the plane of the beam and also in the plane of the trusses
I wonder if he needs all of his 20' spans @ full height or just at the log loading area? Even 2 of the spans with some stout 45's for bracing would do a lot, and for the truss plane. End walls would be just perfect along with maybe an added LVL (front to back) with another set of 45's.(diag. brackets/bracing/gusset) pick your local terminology :D in the middle.
Offline Holmes
  • 1840 house
« Reply #21 on: December 23, 2017, 08:03:34 AM »
 I am not a big fan of setting something 18" tall on top of the posts unless it sits in a full depth welded steel saddle.  The beams could be place between the posts with " joist hangers" or welded hangers. You would be handling less weight, make them up yourself , set them with a lift. You just need to cut the poles higher.
  When they put the trusses on my barn they preassembled 4 trusses on the ground and raised them in place with a crane, 4 lifts took less than 2 hours to put all the trusses up.
Think like a farmer.
Offline Grizzly
  • I wanna go camping!
« Reply #22 on: December 23, 2017, 12:13:08 PM »
711, i want a consistent ceiling height throughout so that i can drive loader/forklift/truck/whatever anywhere in the building. I also want 20ft openings everywhere for the same luxury of hauling wood wherever. Or at least until i start closing in the walls. But you had me thinking there for a while until i realized what i just said.
Holmes, good point. My carpenter was going to notch the poles and create a saddle of sorts but i'll see if he wants something stronger. With your idea of hanging the beams between the poles ....... I don't have 20ft logs to mill my own beams but i could get my rafter guy to make that style of truss to sit in that gap and into the fabricated truss hangers. And that could be a fair bit cheaper than LVL. I'm gonna check that out.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
2000 Miners 3-31 Board Edger
Offline Grizzly
« Reply #23 on: January 07, 2018, 02:06:03 PM »
My daughter roughed this for me. Now, if that idea seems workable all I need is someone to help design a floor truss style of beam that I can build to go in there. Currently drawn for a 4" wide beam but can be done for almost any width.
Offline Iwawoodwork
« Reply #24 on: March 15, 2018, 12:31:26 AM »
I used to own a float house  on ten mile lake , Oregon coast that was about 40' long  25' wide and had a 20' free span center beam for the front room.  the beam was 40'. The structure was over 40 years old when I sold with no sag. The Beam was made using 20" x 8'  3/4" plywood sandwiched between 2"x10"s one above the other, glued and screwed together on each side of the ply, very stiff . we did not have much snow but high winds most winters. I would not be afraid of a 20' span between posts with a sandwich beam made like that. If you wanted more put 1/2" ply on the outside mismatching the ends.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #25 on: March 18, 2018, 08:02:16 PM »
Kinda hard for me to draw but If you could mount some 1/2" thick angle iron in a saddle of the pole and sit your beams on top of the angle and bolt everything fast to the pole that sure would make it strong.
Love machine shop work
and Wood work shop work
And now a saw mill work
Online Don P
    • Calculator Index
« Reply #26 on: March 18, 2018, 09:24:33 PM »
In your mind push on the pole in each direction like a roof on an unenclosed building in the wind. Start welding bracing on that angle :(
Offline Kbeitz
    • My Hobbies
« Reply #27 on: March 19, 2018, 08:57:18 AM »
I agree 100 percent...
looking for my first saw, looking for knowledge
Started by moose207 on Chainsaws
Last post October 14, 2017, 09:56:53 AM
by moose207
thumbup
FF knowledge pays off again
Started by Ianab on General Board
Last post September 13, 2004, 12:29:48 PM
by DanG
Need someone with truck knowledge
Started by Mr Mom on General Board
Last post June 17, 2010, 12:32:15 PM
by Mr Mom
thoughts and knowledge please :)
Started by cutter88 on Chainsaws
Last post May 02, 2014, 10:29:12 PM
by Maine logger88
