Dynamic Green Products Inc.
Author Topic: WADKIN "XE-446" 5 head moulder needing any information available  (Read 789 times)
Offline boardwalker
  • Love the smell of Yellow cedar being milled.
« on: December 28, 2017, 01:35:37 AM »
Hi
Anyone know anything about a WADKIN "XE-446" 5 head moulder. I can't find anything on the internet for some reason but that is the model on the side of the machine. It has digital readouts and looks really clean.
Any information would be appreciated.
Craig
Lucas 8", Laguna CL1200 copy lathe
Offline longtime lurker
Re: WADKIN "XE-446" 5 head moulder needing any information available
« Reply #1 on: December 28, 2017, 04:24:38 AM »
http://www.wadkin.com/products/browse/-/5/-/Moulders
The horses mouth, so to speak. One thing about Wadkin: if they built it they'll back it (well for the first 50 or so years, older then that they might have parts in stock). Kick them an email - they'll sort you out.
Offline timbatrader
« Reply #2 on: December 29, 2017, 04:43:12 AM »
Wadkin went bust a few years ago there is a new company in the UK that has the old drawings etc and can make parts to order but not whole machines
I run a XE220 machine must be about twenty years old now it goes well no plans to change it
The XE series was made on a GS series chassis ( the small slow planer) with high speed jointed spindles outriger bearings etc off the XJ series  so it could run at higher feed speed (100 feet per minute)
so it is a sort of compromise between the fast to set up slow to run GS and the more complicated to set up but faster to run XJ
I don't think there was a XE446 generally the numbers refer to how wide timber it can take ie my XE220 can take a 220 millimeter wide board
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« Reply #3 on: February 05, 2018, 03:30:24 AM »
I have a Ga220 here (9 head) and you have to say they were built to last!!
Cheers
Justin
Gear I run;
Need some help with information on a Smithway, Stetson-ross XL moulder 4 or 6"
Started by boardwalker on Sawmills and Milling
Last post October 29, 2014, 03:45:35 PM
by Cedarman
recycled
Wanted Smithway XL Moulder 2" x 6" or one of the other names it was sold under
Started by alaskasawyer on Wanted
Last post October 27, 2014, 08:45:10 PM
by oakiemac
Trouble with a Wadkin Bursgreen 20" thicknesser
Started by Oakcreek on Drying and Processing
Last post November 16, 2010, 06:50:26 PM
by Oakcreek
Moulder Wadkin Gazelle
Started by Ironwood on Drying and Processing
Last post October 01, 2011, 09:05:11 PM
by Ironwood
