Setter
Started by ladylake, December 30, 2017, 05:27:19 AM
4x4American
Interesting, must be different up there in Canada cause it's metric, but I tend to run as less set as possible.  I tend to prefer about .025" with my setup in unfrozen hardwood...in frozen hardwood I'll run around .015" +/-
With the LT40 and 36hp yanmar it liked .020" in unfrozen logs and .012" in frozen wood.  .012" worked really well for me in frozen doug fir too..that was either with 4 or 7 degree blades I can't remember.  With the more power on the 70 it seems to fancy a bit more set.
Boy, back in my day..
Percy
Quote from: PAmizerman on December 31, 2017, 08:23:45 PM
Perxy, how much set do you run?
.038 ish ;D
I cut mainly sitka spruce, WRC, and Alaskan Yellow Cedar. Soft woods seem to like way more set as they are springy for lack of a better term, compared to hardwoods. I cut about 100,000 bdft of birch waaaay back and I still used the 13 degree blades. Feed rates were scarey fast and I just never bothered setting right out of the box or ever for that matter. While hardwoods are obviously much harder than the softwood, the birch hardwood seems to be more consistant in density than softwood and cuts cleaner ,,,less springy and generally more fun to cut than sitka...sitka is related to Hickory by marrage :D :D :D :D
Pabene
I have had a Cooks single tooth setter. It had some week points, in my opinion, but easy to adjust so it was a good setter for me. There are more things to observe about setting than I have seen here on the forum. All setters I have seen on the market bends the teeth against a horizontal edge. That means the side of the tooth is parallell to the blade body. In other tools you want to see a relief angle in this area. If you are careful and have the setters anvil to push the tooth on a point close to the face, you will have a little better result. If you would press the tooth, on a point close to its back, it can result in a negative relief angle for the side of the tooth.
The teeth on most blades has a back angle about 30° and the back is shaped straight up to the tip. That means the tip, on the outside of a tooth with set, will cut a little wider in the kerf. It is what you need but the margin to bad behavior can be low. I hope you can see it can be critical to perform the set in the best way. I have made some tests to first "pre-twist" the teeth a little and then perform the set in my S.T.S. So far it has been positive.
terrifictimbersllc
Interesting. To confirm, is one thing you are saying, that it should be better to have  the blade clamped deeper so less of the tooth is protruding above the clamp?
Pabene
I have not been able to add photos on this forum yet. A photo would explain better than my words.
If you are looking down to a blade, clamped in your setter the normal way, or a little higher, you can see the teeth in "set groups", left, right and no set. With an adjustable spanner you now can "twist out" the front (face) a little. On the left tooth to the left  and on the right tooth to the right. You can in the same moment with the spanner, "down-set" a little. Then you have to "calibrate" the set in your setter the normal way. Grind the blade the normal way. Now you have a blade with a relief angle also on the outside of each toth with set. (That means you have a possibilty to go so far that the outside of the face can cut not only on its tip.) For the blades I have tested this method on, I have a combination of normal set and "pre twisted" teeth. I think the twist can be about 3°. The pre-twist procedure is enough to performe once, it will last for many grind and set operations.
Percy
Quote from: Pabene on January 01, 2018, 01:13:49 PM
Very interesting. I never spent any time thinking of relief angle in the manner you describe. Looking at the photo of my setter here, I could grind the setting anvils appropriately for achiving what you describe/recommend?
4x4American
Very interesting..I do believe I'm picking up what you're putting down.  Percy I think that it would have to do both sets on each tooth at the same time so that they can kinda push against each other to put the twist in to the tooth so looking at your setter I think you could do that, but wud prolly have to replace the plastic anvil with something more substantial.
Pabene how do the twisted teeth perform compared to normally set teeth?
Pabene
Percy, You can grind your anvils so it will hit the teeth on its face edge. It was the way I started. If you have a dial indicator on your setter it is a good way to go. If you don't have a the possibility to check every tooth it means it is more critical to stop the teeth in correct position in the setter for each set stroke.
4x4American. It is a long story about my steps to how it is for me today. I started to check the cutting angles on new blades many years ago. I wrote here on the forum, last fall, about parts of it. Your question if my blade is better with twisted teeth: yes, I think its better but it is in combination with a back angle of 12°, just at the top of the teeth.
I discovered the need for a relief angle, on the outside of the teeth, when I checked my blades dullness with a magnifying glass. That way is good to see how the wear looks like around the top of the teeth after some hours in the mill.
I think the most important is to avoid, by mistake, to let the setters anvil hit the teeth at the back side. It can result in negative relief on the out side of the teeth.
  Here is a photo (the first time I was able add a Photo here.) on a blade. The twist is not visible but how I like to grind the back angle.
ladylake
Pabene
   Any problem with it feeding with only a 12° angle at the tip of the tooth, seems like lately the rage has been a 40° back angle which to me don't take a nail hit very well.   I'd bet your 12° would take a nail hit good.  Steve
terrifictimbersllc
I think I got your idea about twist in tooth and the relief angle, but to be honest I 'm not sure.
Just to be correct I think "anvil" is the part that contacts the body of the blade, and "pusher" is the part that pushes the tooth (against the anvil).
I am also uncertain that pushing just the tip of the blade enough to bend it outwards by a few thousandths of an inch, is going to take the "twist" out of the tooth, isn't this twist part of blade manufacture?
Pabene
Terrifictimberslic, I am sorry for my English. I missunderstod the text in an other thread. Here "anvil" would be "pusher". So, it is important to let the pusher hit the tooth close to its face. In my singel tooth setter, I set the pusher to push on a point at the middle of the tooth height and close to its face. If the teeth is "pre twisted", the twist remains after many set procdures. I have checked the relief angle, on the outside of the tooth, on some new blades. There are blades with very little relief angle. If you are uncareful it is easy to make it worse. When you are looking down on a blade with the teeth grinded to 30° back angle, all the way up to its tip, you can see it looks like there is a relief angle, but it can be false. If you take a 0.1" drillbit, hold the drillbit to the side of the tooth, just under the tip and horizontal. Now you can see the real angle, the drillbit shall point out, I think at least 3°. (You can also use a caliper, pinch the tooth tipp and you can judge the relief angle.)
JB Griffin
Quote from: ladylake on January 02, 2018, 02:09:21 PM
Pabene
Steve, the guy that sharpens ( really he just grinds at em) blades for work ground a bunch of 7/39s for us but with a 35deg back angle.  Absolutely ruined the whole lot. Feed rate was 25-50% slower, would wander in the cut, blades would "push off" the cant leaving a hump on the cant. Junk.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Pabene
With a normal blade speed in a mill and a very good feed rate, say 75 Feet/min, the blades tooth tips are moving through the log at an angle of about 1°. A relief angle of 12° would be enough for much higher feed but impossible in most mills for other reasons.
When I have cut a 4" nail, it is blue steel chips from the nail on some tooth tips. The steel chips are burned to the tips as the cutting speed is to high for steel. It is about 20 teeth with chips and I take it away from the tips before I starts to resharpen the blade. The blade works as normal after a such mishap.
ladylake
I'm really getting confused here, one guy says they wont cut good unless their a 40°, the next says only 12° at the tip is needed for 75 lf per minute while I'm perfectly happy with the 30° back angle I run.  Steve
4x4American
Quote from: ladylake on January 03, 2018, 05:23:19 AM
He's not talkin about the whole back angle, he's grinding just the back trailing edge of the tip of the tooth to a little 12 degree ramp.  Look closely at the picture he put up you can see it.
ladylake
I can see that perfectly, there is a huge difference between his blade and one  with a 40 ° back angle and both say they saw great.  Steve
Banjo picker
Steve you are not by yourself on the confused part.  I am gonna go back and reread the whole thing.  Banjo
Pabene
Steve, I have the main part of the back at 30°. It is only the top of the teeth as have 12°. The gullet stays in nearly the same volume as the original. I am checking the relief angle at the outside of the teeth. The result is: for a tooth with a hook angle of 8° and a relief angle of 12°,  the  "EDGE-angle" is 70°. The advantage is there is more steel as supports the edge. There are more steel to transfer heat from the edge down to the body.
I am sure that the blades keeps its sharpness better, it cut with a "softer sound" and the finish is smother.
If you compare the teeth on a circular blade with my blade, (see the photo in the thread above), you can see the angles are similar.
I am not sure I understand everything here but in my opinion would a back angle of 40° results in a to pointed tooth. The edge angle for such teeth would be 42°, it is to week and brittle.
JB Griffin
A lot I don't understand in that last post too. But I KNOW this, the Kasco 7/40 is the smoothest cutting blade I have ever tried, and that profile went through at least two designs before being put on the market. That being said Kasco spent a lot of time and money on that EXACT profile and when our sharpener dude changes it the blades won't run nearly as good.
Your mileage may vary, as no two mill or sawing situations are exactly alike.
How thin a point of a tooth can be and still hold up is purely a matter a metallurgy and heat treatment not profile.
Pabene
JB Griffin, I have now seen how the Kasco 7/40 looks like. There is a photo here on the forum from two years ago. I am not the man to say it is good or not without to been able to test it. The most important on that blade, in my opinion is, it has more volume in the gullets. I believe it is made in very good steel, it is sharp and they have very good finish on the grinded surfaces. I think Kascos reason for the 40° back angle is it was necessary to give it a steeper back to be able to make a deeper gullet.
I am waiting for blades with gullets like this but the pitch would be 1.25" or more for 1.5" wide blades. For us with mills with less than 10 kW motor it would help to cut big logs.
!.5" wide blades with 7/8" pitch and also with 1" pitch, has gullets as are filled up with saw dust already when you cut boards about 8" wide. To much sawdust and chips in the kerf creates o lot of problem.
I also think the miss behavior you had after your sharpening process was caused by bad grinding.
I would like to test such 7/40 and I would allow my self also to try 12° on the tip at the first sharpening.
ladylake
(How thin a point of a tooth can be and still hold up is purely a matter a metallurgy and heat treatment not profile)
No way are those little pointy teeth are going to hold up to a nail hit as good as one with some metal behind the tooth.  Steve
JB Griffin
Pabene, I have no doubt that your method of sharpening must work for you. But I seriously doubt that it is answer to all sawing woes. You are most very likely sawing much different sizes and species of wood than the red and white oak, hickory, sweet and black gum, and shortleaf pine that I saw on a daily basis.
Ladylake, band mill blades are made for cutting wood ;), I will stand by my statement. For more than 12 years I have forged knives and other tools and never once did I send anything out to have someone else do the heat treat for me. Do I claim to be an expert on the subject... never, but I know way more than the average bear.
ladylake
JB  So then put a razor blade on the edge of a knife with very little metal behind it and see how it holds up, I'll stand by common sense.  Keep in mind that you switched from a low quality blade that I tried and no way would it saw straight to a high quality blade.  I think the quality of the blade made more difference in sawing than those little pointy teeth.  Another thing how many sharpening can one get out of those little pointy teeth, seem like after a few sharpening's most of the original tooth would be gone.  Steve
JB Griffin
Steve,  I have gotten as many as 14 resharps out of those silvertips thats around 14mbf sawn with that blade. But that blade was exceptional. Most averaged around 6-7. Thats with 36" bandwheels. The main problem with the silvertips are low consistency,  some do good, others are junk right out the gate.
The Kasco blades are upto 4-5 resharps now and are still going.
If you aren't grinding the entire profile accurately the original tooth will be gone from any blade in a few sharpenings.
At this point I will refrain from this thread.
ladylake
Quote from: Pabene on January 01, 2018, 06:45:11 AM
I have my Suffolk setter up and running, works great. The push block is angled well so it hits the tip of the tooth first bending it out a little so no need to worry about the relief on the side of the tooth on this setter.  Steve
