Author Topic: Ideas for delimbing fir trees  (Read 4992 times)
Offline Haymaker101
« on: December 30, 2017, 02:40:02 PM »
Hi,
I have 600, 30 fir trees to clear planted 8 on center. I need a way to delimb the bottom 16-20 of the tree. I will process this wood into firewood. The tops I will burn in the spring.
The branches I need to trim are no more than 1 and the treees do not exceed 10-12 dbh.
I have tractors, grapples, trackscavator, skidsteer,
 And farminwinch available to use.
How would you do it besides which a chain saw? I found YouTube video of whats called a Karsis Oy. They are not found America though, at least not online. I would like to buy something like this rather than try to build on.
Lets hear your ideas, thank you
Offline DDW_OR
Re: Ideas for delimbing fir trees
« Reply #1 on: December 30, 2017, 03:31:15 PM »
as you probably thought this has been discussed before.
here is what i have found
http://www.forestryforum.com/board/index.php/topic,94237.msg1536482.html#msg1536482
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline DDW_OR
« Reply #2 on: December 30, 2017, 03:33:16 PM »
also please update your profile so we can see what country and city you are in.
Offline chubby
  • Staying busy is the only way to stay sane.
    • GRAPPLEPROS
« Reply #3 on: December 30, 2017, 04:02:10 PM »
Sounds like a job for the FARMA-N!
http://forsmw.com/processor/5-15-b-50.0.38.2
Offline DDW_OR
« Reply #4 on: December 30, 2017, 04:22:58 PM »
Offline DDW_OR
« Reply #5 on: December 30, 2017, 04:25:09 PM »
Online barbender
« Reply #6 on: December 30, 2017, 04:52:57 PM »
In the frozen north, all you have to do is skid them to delimb, they all snap off.
Offline Haymaker101
« Reply #7 on: December 30, 2017, 05:07:45 PM »
Im looking for this but in America, not Europe. Anyone seen one before? Sure I can weld and make one, but why reinvent the wheel. Thanks
Offline DDW_OR
« Reply #8 on: December 30, 2017, 05:42:21 PM »
The Stripper Delimber
Offline starmac
« Reply #9 on: December 30, 2017, 07:23:34 PM »
Up until 2 years ago the sawmill had their own logging crews here, it is pretty much all winter logging so they would just use rub trees and pretty much delimb with the skidder, any limbs left at the landing they would run the skidder over them and break them off. There were loggers logging pulp that did the same, when we had a pulp market.
Now the mill does not run their own crews anymore and prefer wood that has been run through a processor head. I do not even like skidder processed wood for my own sawmill either. Even the guy I hauled firewood logs to this year, much prefers wood that has been run through a processor, he has to do a little chainsaw work to skidder limbed wood before he loads it on his firewood proccessors.
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #10 on: December 30, 2017, 07:27:36 PM »
Oh man, I gotta quote that one.  :D
Up until 2 years ago da millin machine had their own logging crews here, it is pretty much all good sleddin season logging so they woulda just use rub trees and pretty much delimb with da skidder, any limbs left at da landing they woulda run da skidder over dem and break dem off. There were loggers logging pulp dat did da same, when us guys had a pulp market.
Now da mill does not run their own crews anymore and prefer wood dat has been run through a processor head. I do not even like skidder processed wood for disguy's own millin machine either. Even da guy I hauled smoked suckers logs ta dis year, much prefers wood dat has been run through a processor, dat guy has ta do a little powersaw work ta skidder limbed wood before dat guy loads it on dat yooper's smoked suckers proccessors.
Offline Haymaker101
« Reply #11 on: December 30, 2017, 07:41:00 PM »
Im looking for the $500 dollar option, not 5k to 120k as shown. Thanks guys
Offline thecfarm
« Reply #12 on: December 30, 2017, 07:44:29 PM »
And you guys have to remember,he only has a tractor. He's not going to bull through the brush without doing some damage to his tractor.
Offline Logger RK
« Reply #13 on: December 30, 2017, 07:52:51 PM »
If it's cold enough & it's not a high production job,tie one end of a long chain to something solid & the other end that's has a slip hook around the tree your skidding out.Pull ahead & if it's cold enough you'll leave the limbs with the chain. Iv never tried it but a Women Skidder Operator I knew told me her & her Dad logged Balsum with a tractor like that.
Online Skeans1
« Reply #14 on: December 30, 2017, 08:27:21 PM »
My question would be are you thinning, clear cutting, or just removing the bottom limbs for looks?
Before we had a processor or a pull through we used a chain flail mounted to the back of a JD 555 track loader with a small shear head for cutting up front.
Offline Haymaker101
« Reply #15 on: December 30, 2017, 08:39:43 PM »
Im clear cutting the area and will stump it on the spring. The area will be replanted with Christmas trees in the spring of 2018. All ground in flat and the trees are planted in straight runs.
Im just looking for a cheap and easy way to delimb the trees so we can put it through our firewood processor. The top of the tree I will burn.
Offline Southside
« Reply #16 on: December 30, 2017, 08:42:04 PM »
I think the "stripper" is around a $5K option.
Online Skeans1
« Reply #17 on: December 30, 2017, 08:44:58 PM »
Maybe a limbing gate would be an option. Are you already in the Noble fir Christmas tree business? Only reason I ask is there's been a ton planted in the last year so they'll be another glut coming in the future.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #18 on: December 30, 2017, 11:09:39 PM »
I'd agree that a limbing grate would be a good way to go :)
Offline starmac
« Reply #19 on: December 31, 2017, 12:14:16 AM »
WOW Jeff, I go to a lot of trouble to not type how I talk, then youse change it right back.
8 trees - any ideas?
Started by gurgling_mrd on Tree, Plant and Wood I.D.
Last post July 11, 2018, 08:48:08 PM
by WDH
any ideas how to make money from a forest while not cutting trees?
Started by MyWorkingForest on Ask The Forester
Last post November 22, 2012, 11:17:59 AM
by SwampDonkey
Ideas needed for removing Christmas trees from pegs - Civic fundraiser
Started by btulloh on General Board
Last post December 03, 2018, 12:03:51 AM
by samandothers
Delimbing with loader
Started by treefarmer87 on Forestry and Logging
Last post March 16, 2010, 09:41:26 PM
by chucker
