Mig Welder
Started by MartyParsons, January 12, 2018, 10:01:28 PM
Skeans1
Or 100% helium on DC Tig welding aluminum is a fun option too. Even pumping some helium in with a Y on a spool gun helps as well.
Dave Shepard
DC and aluminum? That can't end well.  :D
Skeans1
It's just fine, get it good and clean with an etch then SS wire brush then the helium breaks up the oxide layer on the aluminum works great on thick stuff since all the heat goes into the part.
starmac
All of the aluminum stick rod I have ever had was dc, could not be used with an ac machine at all. They may make some ac rod, but I never had any, I did try it with an ac machine once though.
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
