Band mill Router Plane
Started by Kbeitz, January 25, 2018, 01:09:09 PM
Kbeitz
Quote from: Crusarius on February 20, 2018, 07:29:18 AM
if you hold ctrl key and roll the scroll wheel on the mouse that will change your font size that you see.
Yep. But that changes the whole screen. it's only my typing fonts thats small..
Love machine shop work
and Wood work shop work
And now a saw mill work
Crusarius
Yea, as I was responding I saw exactly what you were talking about. I think that is a theme setting Jeff will have to fix.
Kbeitz
I pretty much got it finished. I need to drill two holes for stopper bolts for the limit switch and I'm done.
What a lot of wiring for this little box.
justallan1
 8).........What's the word Mister.
We're dying here wanting to see this thing go. LOL
Kbeitz
I took it all apart today so I can carry it out of my basement. We have had nothing but rain here for the last couple of days. First good day I will get it out and on my mill. Pictures will follow.
Kbeitz
Today's the day... It's coming out....
I got it stuck....   say_what
Crusarius
did you ever get it out? that looks kinda precarious.
Kbeitz
Quote from: Crusarius on February 25, 2018, 02:35:18 PMdid you ever get it out? that looks kinda precarious.
Yep... Tough working by yourself...
Kbeitz
It's out....
Broke a toggle switch... No biggie ...
Got it back upright and ready to go...
Using my crane to help get it back together.
Now I need to fix the broken toggle switch...
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Kwill
Looks like it was an eventful day around your place  :)
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
justallan1
I want to see the pictures of when you put the mill and lathe down there, or did you build the house around them? :D ;D
I do understand your situation though with some of the stuff that I've built indoors.
Kbeitz
Quote from: justallan1 on February 26, 2018, 06:56:51 AM
The lathe was set down the steps with a prentice loader. Never again... The mill I took it all apart and carried each piece down and reassembled. The hardest part was the knee of the mill. I had to lift it high enough to get it started on the dovetails. After the prentice loader set the lathe on the steps I hooked my winch on it and slid it down a sheet of 3/4" plywood to the floor. Then jacked it up and rolled it into place. I don't ever have plans of taking ether one of them out again. They go with the house.
btulloh
Quote from: Kbeitz on February 25, 2018, 06:23:00 PMYep... Tough working by yoursel
Especially when you're the photographer too.  Thanks for pix.  Always interesting.  Can't wait to see it in operation.
HM126
Kbeitz
We have had some super days this week. I got so much to do. I want to see it work to but I want to make some different hold down clamps for the mill before I give it a try. My new toy Bobcat skidsteer has taken my time lately.
I did put my new carb on the Honda mill engine. Runs so much better. Today I had to go get another two loads of free Walnut logs. Busy time of year... Oh... I seen my first spring Robin today...
btulloh
I can see making the Bobcat a priority.  You'll use that everyday.  Good score on that.  Once again, I'm jealous.  :)
HM126
justallan1
What's the good word..... 8) 8) 8) 8)
Kbeitz
Still waiting on E-bay for my hold down clamps....
Kbeitz
Clamps should be here Monday. Then I need to make the base for the clamps to fit on my mill.
Ljohnsaw
We will soon see, but why couldn't you use your log stop/log clamps that you already have?  Certainly your slabs are going to be more than 1½", right?
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Kbeitz
I could but this was part of my build. I want to finish before I try everything out...
Theses new clamps will have a small tilt in them to help hold the slabs down tight to the tracking. It's also only been in the low 30's here with snow on the ground and I'm not ready to play in the cold.
21incher
Aren't you better off letting the slabs float on the first side cut so they are flat when done. I use wood shingles to shim the low spots on my cnc router and then just plane the other side parallel to get a perfectly flat slab. :)
Kbeitz
Until I cut my first slab I don't want anything floating until I see whats going to happen when the bit hits the wood.
Ljohnsaw
Well, my one and only slab was big - 90"+x42" and 3-¼" thick.  I used a Porter Cable 3+ variable speed router with a 3½" bit.  No clamps, no problems.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Kbeitz
Quote from: ljohnsaw on March 08, 2018, 09:45:22 AM
Could you show us what bit you used ?
