Author Topic: Saw Dust Addiction  (Read 3693 times)
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Saw Dust Addiction
« Reply #20 on: January 27, 2018, 08:27:27 AM »
I always have the loader side bubble high which also allows the Debarker to use it's own weight to help engage the log.
Offline Chuck White
  • Sawing Mobile 2005-2022
« Reply #21 on: January 27, 2018, 08:38:47 AM »
Don't forget a hammer or a single-bit axe/hatchet to drive the felling wedge in!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, Retired Mobile Sawyer 2022, 2018 Silverado 4X4,  2019 Subaru Forester.  Cooks Cat Claw Sharpener and single-tooth setter
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #22 on: January 27, 2018, 08:00:27 PM »
And it helps a log sometimes get over that last little hump.  ;D
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #23 on: January 27, 2018, 08:01:16 PM »
Lynn,
   A big log knocked my mill off the supports I had under it and was well over half a bubble off level. Yes, the debarker rested against the log better but then it kept wanting to rotate back when I no longer needed it so on our lunch break I jacked the mill back up with my bumper jack I take along (Another support item to consider taking along) and get it closer to level.
   We had about a 300 bf poplar log on one loading arm. Too big to turn so I pulled out the MM log puller/tuner shown above and it worked like a charm and impressed the heck out of my customer.
Online Southside
    • White Oak Meadows
« Reply #24 on: January 27, 2018, 10:46:14 PM »
WV -
The fire extinguisher is a great idea, I will start doing that, I will thank you now in the event that one day I need to deploy it.  Pretty obvious when you think about it, fuel, fine dust, heat.  What could go wrong?
To the OP - I also keep my alignment tool and the drive belt tension tool in my spare parts tool box, just in case.  Better to have it than to know what shelf it is sitting on 70 miles away.  In the cab of the truck I keep a multi meter and the owners manual when I travel too, gremlins are even worse when one does not have a wiring diagram to at least stare and and pretend to understand.
White Oak Meadows
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #25 on: January 28, 2018, 03:08:31 PM »
WV, Too far past level and you can actually overcome the head weight causing it to rock.  You never want to reach that point.
Online Southside
    • White Oak Meadows
« Reply #26 on: January 28, 2018, 08:36:14 PM »
Magicman -
If you mean rocking front to back I actually use that to my advantage when hitching or un hitching the mill.  I will set the rear outrigger so it is about 8 - 10" off the ground, have the safety chains hooked to the hitch, then slowly roll the head back until right before she rocks, basically at balance point.  Then I can easily swing the hitch onto the ball that last 1" that becomes so troublesome at times to get squared to when working alone.    It also allows me to drop the front outrigger and just roll the head back a bit so I can look to see if I need to raise it up or lower it down when setting up.  Makes for a whole lot less prying with the chrome rod.
White Oak Meadows
« Reply #27 on: January 28, 2018, 08:58:01 PM »
SSL,
   Many of us have learned from that trick to be sure to leave the rear landing gear at least part way down unless you want to see the tongue of the mill about 10' up in the air (Don't ask me how I know that  :D).
   Yes, you can shift the weight when hooking and unhooking but when sawing and leaving overnight you want the landing gear solidly in contact with the ground IMHO.
   When I am hooking up by myself I put a shovel. long sticker or cant hook against the tip of the tongue and back up until I shake or knock it over when I hit it with the ball on my hitch. Shifting the mill left or right to put it on the ball is much easier than moving it forward or backwards, especially if you have several inches of sawdust built up under the wheels. Also I make sure the ball is a few inches higher than the hitch on the mill.
Online Southside
    • White Oak Meadows
« Reply #28 on: January 28, 2018, 09:05:45 PM »
Yea - my mill did the sky gazing thing once too.  On a good note that makes it a lot easier to clean all those hard to reach places from the bottom!!!   :D
White Oak Meadows
Offline Brad_bb
« Reply #29 on: January 28, 2018, 09:55:39 PM »
Chainsaw, wedges, some small wood wedges like 1/8 or 3/16th wedges, and maybe some 1/2 inches too.  Dust brush, paint scraper, Small level, Some short pieces of 2x4, Some 5 gallon buckets, some garbage cans from dust and a dolly to move them.  Axe, bark spud, 6" Makita power planer, hand plane like a no 5.  Framing square, lumber crayon, Dixon makes holders for lumber crayons too at lowes.  Metal/nail removal tools - cordless drill with 1/8" bits ( I like the black Ace brand).  A crescent/Apex nail puller available on Amazon.  A couple sizes of cats paws.  Awl, metal detector.  I like the Garrett hand held wand. Hammer, and a 1/2 inch cheapie chisel.  I have a rubbermaid rolling cart that I keep my tools on, but then I mill inside on concrete.  A tool I don't own yet but want is a bark removal tool for the chainsaw like the log wizard or maybe the kind for an angle grinder.  The dolly will also help you go fill your water jug on the mill.   I also keep a short 3ft ladder on hand because my water and fuel are high up on the LT15go.  You may need it for using the axe on the log on the mill sometimes.
Offline starmac
« Reply #30 on: January 28, 2018, 10:18:43 PM »
It doesn't take but once on that sky gazing thing to remember to leave the back leg partially down. I did that the first day, and just knew the head wasn't going to stop when it reached the end of the mill.
the wedges is always a good idea, as sooner than later you will run out of gas in the middle of a cut and NEED them, I too keep a step ladder. I have never cut any yard trees, so have never needed any nail pullers or metal detectors yet.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #31 on: January 28, 2018, 10:22:37 PM »
Brad, thank you.  There's been a lot of great advice, your's included.
I'm getting my list together.  I have a couple of extra truck toolboxes I'm thinking of using to secure the tools.  I might just pick up an old work truck or older suburban as a sawmill vehicle.  For small money I can preserve my "good" truck and have my tools wherever the mill goes.
LT 35 (Sold) Future Owner Woodmizer LT50, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher
Offline starmac
« Reply #32 on: January 28, 2018, 10:57:54 PM »
You may laugh at one of my tools I hope to never have to do without again. It is a cordless milwaukii blower, I am sure other brands would work just as well.
My wife bought me this after seeing me use my air compressor to clean the mill, I can blow the mill clean in a matter of seconds or blow the sawdust off a 12 foot board from one end. If it went belly up tomorrow, I would have to get another one.
Online Southside
    • White Oak Meadows
« Reply #33 on: January 28, 2018, 11:09:31 PM »
Folks - he's worse than we thought - the disease is progressing faster than expected!!  Next thing we know he will be asking about support equipment - then buy an edger, a kiln will show up before too long.... I am afraid there is no hope.   :D :D
White Oak Meadows
Offline SawyerTed
« Reply #34 on: January 29, 2018, 06:05:00 AM »
 :D :D I also have Fishing Pox....
Offline red
  • we will never forget
« Reply #35 on: May 14, 2022, 07:50:56 PM »
Yes the addiction has progressed !
Offline trimguy
« Reply #36 on: May 16, 2022, 08:17:28 PM »
This was from 2018, yes @southside was right !! Look at him now , Lt50 on order , working on/ with a large wood products company , with a commercial sawmill in mind. 😂
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #37 on: May 17, 2022, 07:35:04 AM »
One could probably could do a case study report on the effects of S.A.D. from just   this one case....:P
From chainsaw all the way to mill upgrades and commercial  sawmill management.  :)
Online Southside
    • White Oak Meadows
« Reply #38 on: May 17, 2022, 12:52:36 PM »
I wonder if his previous infection with fishpox weakened his immune system and made him more susceptible to the disease?  ;D
White Oak Meadows
Offline SawyerTed
« Reply #39 on: May 17, 2022, 03:01:12 PM »
 :D :D Fishing Pox and S.A.D. are slippery slopes.  Neither has a cure all that can be done is periodic therapies. :D :D
No I do not have a BBQ addiction!
Started by Norm on FOOD! FOOD! FOOD!
Last post May 08, 2012, 09:48:17 PM
by Magicman
Addiction
Started by limbrat on The Outdoor Board
Last post August 16, 2013, 01:43:51 PM
by Magicman
I have an addiction.....
Started by upnut on General Board
Last post May 01, 2019, 09:36:14 AM
by alan gage
Like I need another addiction
Started by downsouth on General Woodworking
Last post July 07, 2013, 07:40:49 AM
by Dodgy Loner
