Sawmill Security away from home
Started by WV Sawmiller, January 27, 2018, 10:02:25 PM
Brad_bb
Kbeitz, Do you have these trackers? Have you used them?
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
Jim_Rogers
I second taking a tire/wheel off the mill.
I did that once or twice.
I carry a small floor jack in a box in my truck to help level the mill in rough yards when needed.
It is easy to jack up the mill and put a block under it and lower it back down. I like walking around a mill without the sawdust side tire/wheel on it.
Jim Rogers
JJ
I had a 33 ton hydro log splitter, nice one with honda motor; cub cadet.
while I was away on travel a gang of meth thieves dragged it our of my shed, to steal it.   I had taken off the hitch, so it was still sitting in my driveway when my wife came home.
not fun, sheriff took 45m to show up.
+2 on removing the hitch, otherwise I would have lost $1500 wood splitter.
I now have a camera, ring [ https://ring.com/ ] which replaces outside motion spotlight, and all videos go to cloud.
Very easy to install, and recommended by me.
         JJ
TACman
Cabelas sells a GPS tracker. It's called SPOT TRACE anti theft tracker. It costs $100 for the tracker but then you have to purchase a separate tracking plan.
Stuart Caruk
I think I'm pretty safe.
My mill is welded to pads that are bolted to the concrete. I've recently removed the wheels and axle, and the tongue is gone. It will take more than a bolt cutter to get to it from behind a locked gate with a scary looking Akita. Of course the Akita will help load it if you bring her treats... just don't get between her and mamma...
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
WV Sawmiller
   Sure makes it tough on those mobile jobs though doesn't it?
GAB
Quote from: WV Sawmiller on January 28, 2018, 06:52:42 PM
You're right, but it stays put.
GAB
Quote from: Stuart Caruk on January 28, 2018, 06:36:17 PM
I had a dog like that. Care less about me.Mama burp and the dog would be at her side to make sure she was OK. That dog would of died for her. Twice she scared a person away. Even scared her!!!!!!
Brad_bb
Quote from: TACman on January 28, 2018, 06:22:13 PM
That is what I hate.  In this day and age of technology, that should not be necessary.
4x4American
pull the pin, lift the leg up all the way and see ya!!
Boy, back in my day..
Southside
4 X 4 - I am a bit concerned with how many well thought out ways you have thought about "procuring" a mill.    :D :D
White Oak Meadows
4x4American
Quote from: Southside logger on January 28, 2018, 08:26:44 PM
:D :D my old man taught me real young that to beat a thief/terrorist/mugger/etc you have to think like one.  Also I used to work in da Bronx for a construction company in the shop and we always had to design our own measurements to beat the thieves.  On our conex containers we would weld up boxes over the latches to make the padlock about impossible to get at with any tools, we stopped using chicago fittings on our big air hoses that were on the trucks and started using wacky european ones to make them less desirable, we'd make up chain locking systems for everything on a truck that could potentially walk, etc etc.  Down there we had an extensive population of R&D crews who would constantly test our designs lol.  One time the yard guy parked a mack tri axle dump outside the gate for a couple days to make room in the yard and when he went to bring it in to use it every single light was missing off it and they didnt just unplug them they cut them all out.  i think they even took the heated mirrors iirc
Southside
White Oak Meadows
TACman
Brad_bb,
That's the way it is, they getcha coming and going. It's $149.99 per yr. or $14.99 per month for basic service and an additional $49.99 per yr or $4.99 per month for extreme tracking. With the extreme, it says that you can track coordinates every 2 1/2 minutes. Only problem is, if you have more than one piece of equipment you want to protect, you have to have a plan for each one. Not sure but maybe you could buy the trackers and put them on your equipment and then activate a service plan once your equipment turned up missing lol.
Quote from: Brad_bb on January 28, 2018, 07:34:34 PM
Unfortunately to be useful the tracker requires 2 things, a cell phone data plan, so it can report it's position, and a place (server?) to report it to. Then you can contact that web server and view the latest info that's been uploaded.
Although it might technically be possible to build a web server into the device, it would still take some sort of backend server for you to find the random IP it has from the phone company, and relying on the unit to send data to your phone in real time means both devices have to be online at the same time. If your cellphone is out of coverage or battery, the tracking data is lost as it's not stored someplace.
Now I guess it would be possible to build a device that would upload data to a free account like Google Docs, where you could retrieve it, but you still need the cellular data plan to get it there, and if Google change their rules, the device probably becomes useless.
Kwill
Problem is they don't do anything with these thieves when they do catch them. Slap on the wrist and probation 90% of the time.
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Crusarius
I knew a guy that used a 1/2" cable through his wheels. One day he forgot about it and tried to drive away. Took a good amount of throttle before the cable broke. But it broke pretty easily. I was actually standing next to it when it happened. Needless to say after that he never replaced the cable.
Raider Bill
Friend of mine trailers his bike to central locations unloads it and rides. One time when he came back his truck and bike-less trailer were gone [salt lake city], another time just the trailer was missing [Hershey, Pa.] Now he puts boots on both  sides of the trailer and 2 wheels of the truck even if just stopping overnight. So far so good. Pain in the butt but he sleeps better.
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
flatrock58
I mounted a pintle hitch and chains that can be removed.  Might not make it unstealable, but will make it harder to steal.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
WLC
I don't saw for hire, so no traveling, but we have a lot of druggies and others that will steal the chrome off your bumper if they can.  I've thought about just removing the hitch tongue off my mill and locking it up in the shop.  Only reason I haven't is I'd probably forget where I "put it up safe" at and have to go buy another one in order to find my original.  I do have the tongue latch locked and the mill would be hard to back a truck under to drive off with it and there is always a pile of logs close that makes it even more difficult to steal.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
woodhick
I don't travel with mine much anymore but when I do I know what you mean about not sleeping at night worrying someone is going to take it.  Lot of money tied up in it and thieves are getting more rampant around here.  Now I know they are not stealing it to use since they wont work but to resell.  My suggestion is buy a battery 1/2" impact and remove the hitch head when you park it.  Doesn't take long with impact and while it wont stop them it will make it very hard if they are not prepared for that.  Carry a couple extra bolts with for the just in case you loose one time.
Woodhick
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
TreeStandHunter
Gps tracker or perhaps have someone fab a removeable hitch?
In the process of building my own mill.
