Dynamic Green Products Inc.
Author Topic: Daily Fabrication Thread  (Read 52974 times)
Online mike_belben
  • Pulp Friction
« on: January 29, 2018, 09:49:04 AM »
Just figured it'd be handy for there to be a place where anyone can post up pics of what they built or broke this week, without it hijacking someones thread.
This is a dumper i made this week from a severely bent car trailer axle someone gave me that i shortened, and some wire decking and struts from a pallet rack, plus a chicom lift id welded a boat winch on years ago, and some conduit bracing to resist soak up the twist.
Me and my son have been cutting and splitting OWB fuel for an old man on his pasture and my truck just cant drive out there, but his 4wd quad can so itll solve that problem.  I only get paid if the wood comes out and gets dumped in a carport.  Small loads to keep from tearing up the field.
Not a terrible place to work.
Revelation 3:20
Online LeeB
Re: Daily Fabrication Thread
« Reply #1 on: January 29, 2018, 10:36:57 AM »
And here I thought by the title it was going to be a place to tell lies.  :D
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #2 on: January 29, 2018, 11:00:13 AM »
If it doesn't work as a wood hauler, you could make a mighty big catch and release possum trap! ;)
Offline sprucebunny
  • Gender: Female
« Reply #3 on: January 29, 2018, 11:51:55 AM »
Panel cutter for 8mm polycarbonate greenhouse panels.
Edit: Didn't see this was in Forestry and Logging. Sorry I'm off topic  :-[
Online mike_belben
  • Pulp Friction
« Reply #4 on: January 29, 2018, 01:28:23 PM »
Id do better to bait it with a little copper wire and some meth tied to a 12gauge trigger!
Revelation 3:20
Offline Puffergas
    • Puffergas
« Reply #5 on: January 29, 2018, 05:02:08 PM »
Tiny forwarder. Well, kind of a cross over. Cross between a skidder and a forwarder.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
Offline teakwood
  • Switzerland
« Reply #6 on: January 29, 2018, 06:46:31 PM »
Mike: Are you sure Walmart isn't missing some shopping carts?  :D :D
Offline JesseA
« Reply #7 on: January 29, 2018, 09:43:34 PM »
Mike do you have pictures of making those ring chains you built for your tractor? What size round bar did you use for the rings?
Online mike_belben
  • Pulp Friction
« Reply #8 on: January 29, 2018, 11:02:15 PM »
Theyre not missing.  I know where they are.
Man down man down
Jesse i will try to find pics.  I think 1/2 for the rings and 3/8 for the rest
Revelation 3:20
Offline BargeMonkey
« Reply #9 on: January 29, 2018, 11:19:05 PM »
 One more project that will be wrapped up this week. Like anything I didn't ask around enough and bought a set of axles that needed more love than I knew about, what should have taken a few weekends took 3 months but it's done now, lack a few things and some new lights and she can be back in the woods.
 took some work to gut the old axles and suspension, all new brakes, cans, replaced every piece of air on the whole thing.
Offline woodmaker
« Reply #10 on: January 30, 2018, 06:41:55 AM »
I love the idea of this thread: there are so many fabricators on this forum,and so many interesting ideas. It may force me to learn how to post pictures ;D
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Online Skeans1
« Reply #11 on: January 30, 2018, 07:24:22 AM »
My last project before we had to move our shovel.
Then cheap trick for bearing race removal run a good bead on the inside of the race I prefer tig for this myself but might can work as well.
Online mike_belben
  • Pulp Friction
« Reply #12 on: January 30, 2018, 08:35:17 AM »
Found em.. These are the jigs, one on each side of a cutoff, clamped in vice and had a torch holder and a rod holder so while i was working one the next was heating up.
Revelation 3:20
Online mike_belben
  • Pulp Friction
« Reply #13 on: January 30, 2018, 08:39:00 AM »
Quote
Works great on valve seats and dry sleeves too.  Nice stick holster on the trailer.
Revelation 3:20
Offline Pclem
« Reply #14 on: January 30, 2018, 08:51:34 AM »
Gonna be a favorite thread for me too. Good idea Mike!
Dyna SC16. powersplit. supersplitter. firewood kilns.bobcat T190. ford 4000 with forwarding trailer. a bunch of saws, and a question on my sanity for walking away from a steady paycheck
Offline JesseA
« Reply #15 on: January 30, 2018, 09:10:34 AM »
Did you bend the rings hot or cold?
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #16 on: January 30, 2018, 09:17:02 AM »
I don't know why I never thought of making my own chains. I think of making everything else
Online mike_belben
  • Pulp Friction
« Reply #17 on: January 30, 2018, 10:51:08 AM »
Red hot.  Dont bother trying to duplicate until you build either a wood fired or waste oil fired rod heater.
Revelation 3:20
Offline firefighter ontheside
  • I like trees.
« Reply #18 on: January 30, 2018, 05:36:42 PM »
Technically finished this last week, but this is my log loader.  A chain connected to each end goes over a farm jack and lifts log up level with the mill and then I can roll it on with a hook.  Im not much of a welder, so most of it was welded by a guy at the firehouse.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Online mike_belben
  • Pulp Friction
« Reply #19 on: January 30, 2018, 07:48:37 PM »
Built bunks for when the basket is off, then headache rack and gear holsters. It passed the test, dumped real easy.  off to the cattle farm tomorrow with it.
Revelation 3:20
Daily carnage thread
Started by mike_belben on Forestry and Logging
Last post Today at 09:20:28 PM
by chevytaHOE5674
Whats best for cutting steel for fabrication
Started by chainsaw_louie on General Board
Last post February 08, 2006, 06:28:45 PM
by barbender
BANDSAW SHINGLE ATTACHMENT FABRICATION
Started by Polly on Sawmills and Milling
Last post December 21, 2006, 08:43:31 PM
by Polly
2011 Pig Roast Thread (now the RSVP Thread Please let us know if you might come)
Last post May 29, 2012, 10:47:47 AM
by Jeff
