Recent
898 Guests, 1 User
Welcome to The 2025 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
Does anyone know how much a case 850b loader will lift with forks? I have some 10K pound logs That I need to load on to a sawmill deck about two feet high. The Case literature says 7500 lbs with a static tipping load of 12,800 lbs. I think they mean 7500 lbs safely at full height. The loader I am...
Read More
0 Comments
Trying to locate a good used mandrel with bearings carriers, good collars and a 24-26 in c belt drive pulley. It would be replacing an old farquar that was on the mill, the old one was 5ft long 2'3/16
0 Comments
I installed the Woodmizer Power Feed on my LT15 3 weeks ago. My first comment is "why did I wait so long!". It is great and saves so much hard work, especially easy on my back.
A few details, this is an electric mill that is stationary.
Now for the problem. It worked great last week but today I ran into problems. First, even though I took the rope off the end when not in use, it was too loose and needed tightened (a new knot). Now when I put the head in reverse, the mill shuts off. It works fine moving forward but not in reverse. My solution while sawing a very large red oak was to move the head back manually.Read More
1 Comment
At 84 probably last logging job.
7 Comments
I have my gearmatic 119 out of the TJ 240E and Im thinking about changing all the bearings while i am working on the clutch and brake.
I need to get the end play and backlash specs for the ring and pinion so if i have to shim the pinion i will set it up right. does anyone have these specs?
I also have beel looking for a bearing and seal kit for this winch. does anyone have a source where i can get a kit or do i have to get the bearings and seals individually( is it cheaper to do it that way. Read More
1 Comment
Pages: [1] 2 ... 40
