gearmatic 119 backlash
Started by tberry, July 01, 2025, 10:01:01 PM
tberry
I have my gearmatic 119 out of the TJ 240E and Im thinking about changing all the bearings while i am working on the clutch and brake.
I need to get the end play and backlash specs for the ring and pinion so if i have to shim the pinion i will set it up right. does anyone have these specs?
I also have beel looking for a bearing and seal kit for this winch. does anyone have a source where i can get a kit or do i have to get the bearings and seals individually( is it cheaper to do it that way.
Im going to do the winch first and then tackle the transfer case
BargeMonkey
Harold's -  Randy Nason. About the best place I know to go for older parts. 207-942-8331  he should have whatever you want. Get all my 440D winch parts from him.
tberry
Thanks Barge
onkey, I will give him a call
