Tools collected, timber prepared, framing begins. Update 1 - Hands on hewing
Started by nebruks, July 24, 2011, 05:15:01 AM
nebruks
Quote from: bic on August 08, 2011, 06:48:19 AM
great workmanship nebruks
I'm curious as to how you cut your post groves for the log infill to slide in, to neat for chainsaw, router perhaps??
thanks ahead bic
Hey
About the making of long grooves in the posts. I made so: at first with circular saw I made a 5 cutlines and then with the 2 inch chisel I took out the wood. The groove is 2 1/2 inch wide.
As I do not have any drilling old school mortisers at the beginning I have tested the possibilities to do this drilling a several holes with my 2 inch hand drill and then chisel cleaned the notch/mortice/groove. But it took quite a lot of time so I decided to use a circular saw just for that part of joint. If I had the drilling morticer - I would do the job with this hand tool.
Bill Gaiche
nebruks, Thanks for sharing your talent and photos. This is really interesting and will be fun to follow. I can't even imagine doing what you are doing by yourself. Everyone that does homes like this has to have a lot of pride in there work when completed and then living in that structure. Keep up the good work and good luck, bg
Thehardway
Nebruks,
How were the timbers milled after you harvested them and exactly what species are they?  Very nice work and very ambitious project.  Can your  homesite be viewed from Google Earth? I find it gives an interesting perspective on the project to see where and how it is sited and then watch as it is updated.
LOGDOG
nebruks
Quote from: LOGDOG on August 21, 2011, 04:39:09 PM
How is your progress coming along Nebruks?
I just made an update of the topic. You can see the hewing process at the beginning of the post.
LOGDOG
Looks good Nebruks. Man I cringe every time I see you in sandals instead of steel toe boots doing that chopping and carrying heavy beams. Be careful out there. Looking forward to seeing your house go up.  :)
nebruks
Quote from: LOGDOG on August 22, 2011, 04:22:24 PM
Don't worry man... As you see - my hewing technique is standing at the inside of the log - so it is safer to hew when you stand behind the log.
nebruks
Quote from: Thehardway on August 10, 2011, 08:33:26 AM
Nebruks,
The timbers were milled on a portable sawmil. Mostly I have harvested 120 year old spruces.. My homesite can be found in Google Earth - but it is very old photo you can see from the air that has been taken about 6 years ago.
LOGDOG
Quote from: nebruks on August 22, 2011, 04:57:23 PM
I noticed that.  :) Good idea. I was going to ask you how you maintain a consistent bevel on your ax blade with the circular stone? Just eyeball?
nebruks
Quote from: LOGDOG on August 22, 2011, 05:10:54 PM
I was grinding the axe blade on a grinding machine at first then I am just getting the razor sharpness with a circullar wet stone. The blade is quite sharp and thats what I need.
LOGDOG
Do you have a preferred degree of bevel that you like to maintain? I could tell it was nice and sharp when you were using it to shave towards the line. (Looked like maybe that's what you were doing anyway.)
Brad_bb
That video is too professional for a timberframer.  I think we need to give you a new name: "Hollywood Hewer".
"you might consider getting into better physical shape before attempting such a large project"- definitely a sarcastic and comedic remark.
We may need to all contribute some money to buy you a new pair of shorts.  Those ones in the video have so many holes, there isn't much material left.  :D
LOGDOG
Yeah but Brad, I have to say ... I smile every time I watch a video by Nebruks. Especially when he's in sandals and shorts and I'm in a stuffy suit and tie. He's livin' my dream.  ;)
nebruks
Quote from: Brad_bb on August 23, 2011, 03:59:04 PM
Thanks for your charity aims, but I finally made "new" shorts from some old jeans. As you can see in the video when I sharpen finishing broad axe - I am in "new" shorts.... :D the old ones unfortunately gave up. Today I made first girt with some unusual joints. Will post some pictures lately...
