Tools collected, timber prepared, framing begins. Update 1 - Hands on hewing
Started by nebruks, July 24, 2011, 05:15:01 AM
nebruks
http://www.youtube.com/watch?v=pfYx0CuO21k
I have started to hew the logs that I have harvested in last winter for the walls of our home. I need to hew 60 logs. Each log is 21 feet long. I am hewing a pine at the moment. I am using Gransfors Bruks 1900 broad axe for squaring and joggling and for the finishing I am using very special axe for me - the one that I bought a year ago from one old man. The finishing broad axe is approx. 200 years old (that can be determined from the ornaments on it) and have not been used a lot. It weights about 12 kilos.
I have made all posts, sills and knee braces. After hewing I will be continuing working on the frame.
____________________________
The moment of truth has become. The foundation and the ground works are over. Now the framing has started. All the timber is prepared by myself in my forest at the right phase of moon in deep and cold winter.
I have designed my family house and I will build it till the end only by myself. As much as possible I am doing with human energy. So I don't want to consume the other ones. The house will have a traditional timber frame and the walls will be filled with hand hewn logs in one layer and then insulated with pine wood shavings mixed with clay. The roof will be apsen shingled as traditional here in our country.
At the moment I have made all the sills with floor joists and half of the posts.
Oh the strength of youth.   :)
I look forward to watching your progress.   smiley_thumbsup
scsmith42
Quote from: Magicman on July 24, 2011, 08:42:22 AM
Indeed, this should be a great thread!  Best of success to you on your project, and thanks in advance for sharing it with us.
Tom's 3638D Baker band mill
Buck
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
sparky1
looks like you have quite the project!! looking forward to seein more photos too!
Shaun J
piller
It looks like you are off to a great start on your timber framing project!
Can you describe in more detail your foundation and the infill system for your walls?
Thanks, looking forward to more pictures.
nebruks
Quote from: piller on July 24, 2011, 07:01:00 PM
Hi.
My foundation (under earth layer) has made out of concrete filled with rocks. The upper part has made out of hand splitted rocks that hold together with clay/concrete mortar. The thickness of the foundation is 60 cm. Under the half of the house is basement.
The wall infill system will be:
1st layer - Hand hewn pine logs with tenons on both sides (160 mm thick) that will join in the mortise inside the posts (the long groove) that you can see in the photos that I have posted below.
2nd layer - 250 mm thick pine wood shaving mix with dry clay.
3rd layer - 25mm thick pine boarding (as the rough siding)
4th layer - 25mm thick vertical pine board siding (as the finishing).
So the whole thickness of the wall will be approx 50 cm.
I am the "victim" of the ecological philosophy - so that's why I was looking for possibilities to insulate the house with natural materials.
The realistic design photo is one prototype of my house. I took a picture of it and then in the Photoshop placed it just in the place were my house will come up. So my house will be very similar to the one you can see in the picture.
dukndog
Looks great and can't wait to see more!!
On another note, what software did you use on the design pictures? Is it  Google Sketchup??
DnD
WM LT-15G25 w/PwrFeed, Mahindra 3510, Husky 385xp, Stihl MS261 and a wife who supports my hobby!!
It appears that the foundation is wider than the actual structure.  Wouldn't this be a problem area with water entrapment?
piller
Thanks for the info about the foundation and infill system.  I also like using all natural materials if possible.  So the wall structure is horizontal hand hewn pine logs on the inside (in between the vertical posts), vertical spruce boards with clay/pine shaving infill, horizontal rough pine siding, and vertical pine finish siding on the outside?   Should be very strong, lot's of thermal mass, and good insulation!
Will you be using nails to attach the spruce boards and the layers of pine siding?
nebruks
Quote from: dukndog on July 25, 2011, 07:14:19 AM
DnD
Hey.
Yes I made the simple design sketches in Sketchup. It is easy and very user friendly software.
nebruks
Quote from: Magicman on July 25, 2011, 08:01:05 AM
The underground foundation is 60 cm wide. The foundation over the earth layer is approx 55 cm. The wall will be 53 and there will come a leveled and board all around the foundation after the finishing siding will be made. No water will be able to damage anything.
nebruks
Quote from: piller on July 25, 2011, 10:25:57 AM
Yes you understood the wall structure precisely right. I am not yet decided about the nails of the siding placing. The alternative is pegging them on glue. But the whole house will be built 98% without any metal parts.
frwinks
sounds and looks like you're having fun and that's what building a homestead is all about IMO.  Embrace every moment of it 8)
Tullivor
LOGDOG
Looking forward to seeing this thread develop. Nebruks ... tell me about how the phase of the moon factors into when you harvest the trees. You're the first I've heard comment on it.  :)
bigshow
Nebruks,
you might consider getting into better physical shape before attempting such a large project LOL.
I never try anything, I just do it.
clww
nebruks- I'm going to really enjoy following this thread, so keep it coming! smiley_thumbsup
Many Stihl Saws-16"-60"
18-Wheeler Driver
tonto
WOW, I'm tired just reading this thread. I am jealous of people with such talent. Looking forward to following this one. Tonto.
Stihl MS441 & Husqvarna 562XP. CB5036 Polaris Sportsman 700 X2. Don't spend nearly enough time in the woods.
ljmathias
And it's not just the talent, which there is clearly there aplenty, but the energy: if I had half the energy and the experience (won't call it wisdom ever) that I do now, what couldn't I get done?  Oh, well, I've learned to plod where I used to storm ahead: plodding is slow and sure, and gives me more time to see my mistakes coming at me!   :D
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
nebruks
Quote from: LOGDOG on July 28, 2011, 10:23:19 PM
Hey.
There are over 2000 year old heritage of the rural life in our country. Many years ago people were a part of a nature (so now we are going to be a part of a robots).
The people knew the meaning of every kind of a grass that grows in the meadows. Also they knew everything about the trees, like for an example when is the best time to harvest them for buildings, for less shrinkage, for long lasting, for instruments or furinture...
The best time to harvest trees is deep and cold winter.
In winter trees goes to sleep. Tree is full of resin and all the water circulating process in it has stopped. So you take down the tree while it is beeing asleep in it's best "health".
Here in my country the best time to harvest is in January and February. Our ancestors trough the years of experience knew even the right day and even the hour when is the best time to get down the tree. For all kind of conifers best time of harvesting is first three days when the new moon rises. For all the trees with leaves (such as oak, ash, maple) best time is first three days when the old moon becomes.
Jacob
nebruks
Quote from: bigshow on August 03, 2011, 03:50:20 PM
Nebruks,
Sorry, but I did not understand the meaning of your comment...
nebruks
Quote from: ljmathias on August 06, 2011, 09:40:20 PM
Lj
"The lyf so short, the craft so long to lerne."
GEOFFREY CHAUCER, A Parliament of Fowls (1343-1400)
bic
great workmanship nebruks
I'm curious as to how you cut your post groves for the log infill to slide in, to neat for chainsaw, router perhaps??
thanks ahead bic
LT 28 Woodmizer
where there's a mill there's a way
ljmathias
So the man is well read as well as well skilled!  Great quote, and as I get older, more and more appropriate.
I think bigshow was just "pulling your leg," as we say over here- making a joke about your physical fitness which clearly is not in need of improving.
Keep up the posting on your progress- we love it.  It's a little time consuming, but I've found it's a lot easier if you do it in small bites every day or two.  If you wait too long, and have too much to cover, it becomes daunting, kind of like building a house: if you look at the entire thing and all the work involved, it's hard to imagine ever getting it done, but if you just focus on one small step at a time, well then it gets done.
Lj
