Quote from: sawguy21 on April 06, 2021, 02:26:09 PMHow are you coupling the engine to the drive? I assume being from a generator the crankshaft is tapered.I ended up machining a taper into the centrifugal clutch/drive pulley.
I'm interested in learning how the Predator works out. I've been considering the Lifan 24HP as an upgrade for my 18HP Briggs.
Quote from: marty3d on April 07, 2021, 11:45:50 PMQuote from: sawguy21 on April 06, 2021, 02:26:09 PMHow are you coupling the engine to the drive? I assume being from a generator the crankshaft is tapered.I ended up machining a taper into the centrifugal clutch/drive pulley. I am a novice machinist, and this was the first time I tried to do an internal taper - on my 1919 Sydney lathe. It didn't come out perfect so I used Loctite 660 to fill the gaps and make sure the two parts rotated together.
Started by scottmtfarm on Sawmills and Milling
Started by samdland on Sawmills and Milling
Started by POSTON WIDEHEAD on General Board
Started by barbender on Chainsaws
