WM wide heads
Started by KWood255, February 03, 2024, 09:56:00 AM
KWood255
Quote from: jpassardi on February 09, 2024, 07:03:07 AMSame here: my gasifier will take 30" but I went from cutting 24 to 18 for ease of handling. I don't really need the xtra capacity anyway.
Back on subject: definitely go wide, if nothing else you don't have to fight the guides past logs with carbunkles (intended misspelling smiley_smug01 ) and flares on them.
I'd love to see the details on your gasifier! That's a projects for another day.
Sixacresand
I assume the wide mill owners don't have wave problems while milling width capacity boards.  I have not read of any problems.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
farmfromkansas
Do you need to use wider and thicker blade on a wide head?
The wider apart your blade guides are the more susceptible your blade is to produce a wave when encountering knots, twisted grain, etc. same as with a non-wide.
Proper blade guide alignment, blade selection, sharp & properly set blades, proper drive belt tension, and sawing speed control are all paramount to reduce the possibility of wave problems, again, same as with a non-wide.  :thumbsup:
SawyerTed
It's real easy to saw too fast and make waves with a wide model when cutting wide cuts.  Once a sawyer gets used to slowing down a bit, flat cuts return. Don't ask how I know...  smiley_headscratch
It is better to run wider thicker blades generally.  I'm running 1.5" .045 thick blades and get better results than with 1.25" blades.
Crossroads
No regrets on getting the wide head. At the time it was only an $800 upgrade and worth every penny.
Dave Shepard
I'm going to be stretching my 2008 LT40HDD51WR to a widehead later this year, at whatever point my band stash and workload are at a low point concurrently.
Interestingly, Wood-Mizer says the widehead has a 6" increased capacity, but the head is actually 6.5" wider, and the bands are 13" longer, not 12".
I am just going enough wider to make mine a wide head, no more. I know someone who has an adjustable LT50 up to 47". That really is not what I'm after. I will find another way to tackle anything a wide head can't.
