Author Topic: Logosol ph260  (Read 305 times)
Offline jessepettengill
  • Trees and stones will teach you...
Logosol ph260
« on: December 31, 2020, 11:14:44 AM »
Hey Friends,
I was wondering if any of you had the Logosol ph260 4 head moulder.  I am wanting to make 2 inch v-match flooring, and interior moldings, and do this for maybe 5-8 small buildings a year, for multiple years.  Can this machine handle that?
Also, I see that wood-mizer has a comparable machine--almost identical really.  Has anyone done a side by side review?
Thank you so much in advance for your knowledge?
Kindly
JP
Online Southside
    • White Oak Meadows
Re: Logosol ph260
« Reply #1 on: December 31, 2020, 02:01:32 PM »
Woodmizer bought the company that made the Logosol branded moulders a couple years back, I can't remember the name of it, so they are the exact same machine.
Offline scsmith42
    • Whispering Pines Farm
Re: Logosol ph260
« Reply #2 on: December 31, 2020, 04:26:36 PM »
I had the Baker version for a few years.  It's not a machine that I would want to use for production volume work.
My biggest problem was that it just wasn't robust enough for making 1000 - 2000 sq. ft of flooring at a time.  Chip extraction was poor, and the feed rollers would get chips embedded in them and then slip, which then required us to force the boards through it.
I had to replace bearings on some of the feed rollers before the machine had even 300 hours on it,
Perhaps the Logosol is a stronger machine, but an older Weinig, Mattison, Woods, etc may provide you with better service.
Tom's 3638D Baker band mill
Logosol PH260
Started by logloper on Drying and Processing
Last post February 17, 2011, 09:10:54 PM
by AvT
First run on logosol ph260
Started by MikeH on Drying and Processing
Last post July 16, 2007, 02:27:58 PM
by Dodgy Loner
Logosol PH260
Started by boardmaker on Drying and Processing
Last post September 25, 2014, 10:05:51 PM
by scsmith42
Logosol PH260
Last post December 04, 2010, 08:20:39 PM
by beenthere
