Smoke House Build
Started by campfire courage, January 11, 2014, 12:43:51 PM
campfire courage
You know what you like, I like brown sugar, Garlic, not so much salt, pepper, and I use some olive oil as a binder. I also use some italin seasoning mix. Oh, and maybe more garlic. :}
You can add anything and try it. do some small batches for a test,
Wood is my life, Saw it, drag it, mill it, burn it, build with it, cook with it, heat with it.
WoodMizer LT 30, Kabota 3940, Log Arch, Stihl saws.
LeeB
Mine has sugar, I'll have to try the brown sugar. Pretty much most of the other stuff you mentioned and powdered milk for a binder. I learned to cut way back on the salt called for in the original recipe I started with by quite a lot. Lots of garlic does make it good. I also like to add a little jalapeno powder for a kick.
ely
thanks, this is my new favorite thread.
Chuck White
Anyone ever tried smoking a loin or a quarter of venison!
I think I'd try it if I had a smokehouse.
Tom L
Quote from: Chuck White on January 14, 2014, 02:25:24 PM
I've tried it and didn't like the way it came out, maybe because the meat is so lean, or it just may be me
pork smokes much better IMO
Planman1954
Yeah to the venison! My friend Jimmy used to smoke a deboned quarter in his grill/smoker for 8 hours. Then he would super thin slice it on his slicer, and then freeze it and use it for sandwiches. It was GOOD.
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
21incher
Great job on the smokehouse. I have enjoyed following the build. About the venison, make peperoni out of some of it.
coxy
i know this is an old post just wanted to see how things was going
