what size chainsaw to keep near the bandsaw
Started by Gadrock, February 01, 2014, 07:38:22 PM
mikeb1079
a husky 346 is an excellent mill saw but pretty much any 50-60cc pro saw would be my recommendation.  yeah the pro saws are more expensive but with care it would probably last you a lifetime.
that's why you must play di drum...to blow the big guys mind!
homebuilt 16hp mill
99 wm superhydraulic w/42hp kubota
I always kept my Echo CS300 and the Echo CS670 handy to the mill.  The 300 is an ultra-light climbing saw and I much prefer it for small stuff the 14" bar will handle.  The 670 has a 32" bar but it is heavy for an old guy.  If I get back to sawing, I'll get an electric saw and blower.
ladylake
I use my Echo CS400 all the time around the mill,  I have 50, 60, 70, 80 and 90cc saws but only bring them along if I going to make some big long hard cuts.  That CS400 will cut through a 20" WO fast, not near as fast as a 70cc but fast enough if it's only a couple of cuts.   Steve
terrifictimbersllc
I carry MS-200T 14", MS-460 20", and MS-660 36".   Length and power are used more often for trimming off log flare and bumps to allow clearance, than for cross-cutting.  Having more than one saw is a good thing too when one develops problems and it is important to keep moving.  If I milled at home and had plenty of time one 20" saw somewhere in the MS-260 to MS-460 range would be fine.   I use the MS-200T whenever possible, it's a pleasure whenever this little bumblebee does the job.
caveman
We keep either the little Echo CS 4400 or the Husquvarna 359.  Both start easily but the Husky cuts a bit quicker. I do not think that it really matters what saw you have near the mill as long as it starts easily and cuts adequately.  It is often difficult to prevent your helpers from cutting into the sandy ground and dulling your chain.  The main purposes for us to have a chain saw by the mill is to cut off dirty ends of logs and to cut up slabs to burn out stumps while we are sawing.
Caveman
Caveman
dboyt
Husq 365 with 24" bar around my Norwood.  I run into a lot of logs with flair butts that need trimming, and that takes a long bar.  It is a bit heavier than I would use for just trimming stubs and cutting slabs, but a good all-around saw.  I use the same saw out in the woods for logging.
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
shelbycharger400
Run the biggest you can afford,   several times I've had to do freehand ripping when the log was too long on the mill.
kevin19343
I have soooo many chainsaws I've probably forgotten a few, but generally I'll use my Echo CS3000 or my Stihl 020T at the mill.  Small, lightweight and most of all, reliable.
rph816
We keep 3 stihl's around with 16, 20 and 36" bars.  The 20 gets used most often.  The saw I keep at my place is a craftsman 42cc 18" saw that starts easy, runs good and has never let me down.  18-20" is a great size for most anything a bandmill will handle.  The Stihl MS660 Magnum with the 36" bar breaks down the logs that are too big for the mill, but if you don't come across too many of those 20" will do just fine. - Ryan
P.S. it's no joke backing over a stihl with the skid-steer ...
scully
Sorry, I have used all the big names . Right now Dolmar does it for me ! The 6400 is the best 5hp range saw I have ever used . As for bar sizes on it 18 to 32 inch . That help any ? I supoze they all have there merits ,but I would get a pro grade saw as opposed to a bargin outlet homeowner grade .
I bleed orange  .
backwoods sawyer
Quote from: scully on February 03, 2014, 04:36:42 PM
smiley_thumbsup smiley_thumbsup
heavyer bar and chain longer life motor make the pro worth the extra cost. when climbing around a log on the mill, or trimming a hang up enough to clear, guide, carraige the lighter well balanced saw is ideal. But having the longer 32" saw to reach in can trim some spots that the shorter bar dont reach, advantage of the shorter bar is there are less teeth to sharpen when you nip a piece of metal, keep the rpms down when cutting in those tight places. :o
Backwoods Custom Milling Inc.
JB Griffin
350 husky 18" or 365 husky 20"
workin on my first stihl a 038 might use it when I get it done.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
diesel pap
i have a 359 husky and 025 stihl that needs work. magic man said a 028. i have a 028 wb thats in a box that my dad bought many years ago new. it was the best all around saw i ever used. we wore it flat out and i tore it apart to rebuild but didnt follow thru. i put it in a box because my dad gave it to me before he died in 92. i would like to find parts and rebuild it.
I rebuilt my 028 with a used jug, piston, bearings, etc. that I got from FF sponsor Scott at Chainsawr.  Chainsawr
isawlogs
 Saw size matters little around the mill, your logs should be cut to length and delimbed, that being said, all won't be so. Some will have some protruding knots that will take the use of a saw to deal with, how big a saw to cut a knot depends on how much faster you cut the knot. Almost any size will do, as long as you are comfortable with the saw you use, some like a bigger saw, some like then smaller, I have many saws here to choose from, my go to saw is either a 034, or a 036 with 18 to 20 inch bar, but I have gone on sawing jobs with a 250 or the 170, ( Stihl ) and they have done the job. All they will do is some times cut the end of a log that is to dirty to clean, too crooked to saw or cut off a knot\limb for the mill to be operated safely.
   Marcel
Finn1903
Depends on the size logs you will be milling.  My Stihl 028 super with an 18" bar and chain is the one I use the most, but I have pulled out the 440 for big oaks.  The 028 will go through about anything, just takes a little longer.  I recently picked up a 361, great saw that pulls a 20" bar and chain.
I always take my saw, the 028, with me on mobile jobs.  The customer usually has their own saw, but, my saw is a good backup if their saw turns out to be inoperable.  At that point the mill is idling and we have to get the blade back to work.
WM LT40HDD47, bunch of saws, tractor, backhoe, and a loving wife.
JustinW_NZ
My go to mill saw is a stihl ms-250 with 18" bar
nice and light to get around things while on the mill.
I use something bigger for logs off the mill.
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, 10ton wheel loader.
sawdusty1
Woodmizer LT15
Husqvarna 550xp
Husqvarna 372xp
Husqvarna 350
Husqvarna 55 Rancher
Husqvarna 181se
Kubota L4701
isawlogs
 Danny, I have cut logs too crooked for the mill , I have also cut ''logs '' too small for the mill.   ;)  Have had to trimm logs too big for the mill.
   Marcel
DGK
I have 4 Stihl chainsaws, 260, 460 & 660. The one used most at the mill is the 260 with an 18' bar.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
21incher
I use my Stihl MS 290 with a 20" bar. Since I switched to Baileys narrow kerf chains it allows me to trim down oversize logs to fit my mill without bogging down.
Brucer
I use either of my 70 CC saws with 24" bar, because that's what I have. Those saws are perfect for bucking logs in the yard but 90% of the time are way more than I need at the mill. In fact, I don't usually keep them near the mill unless I'm going to have some long slabs to buck in half.
I'm planning to get a small Stihl this season just for parking by the mill. The odd time I need something bigger I'll just fetch one of the big saws -- which is what I do now, anyway.
In the end, you've got to figure what will work best for your particular operation.
Bruce    LT40HDG28 bandsaw
