food dehydrater for small wood pieces
Started by yukon cornelius, February 14, 2014, 01:57:06 PM
Quote from: terrifictimbersllc on February 22, 2014, 05:33:59 PM
Can someone explain why is there a fuss about putting metal in a microwave, when the merry go round rack the plate sits on is made out of metal?
Every microwave I've ever had the merry go round was made of glass?
I guess it could be metal, if it was earthed, then it would be just the same as the metal case, and just reflect the microwaves around the chamber.
But random bits of metal in the intense electromagnetic field usually results in arcing, and all sorts of other exciting stuff.  :D
Busy Beaver Lumber
Ok Terrific timbers let me try to explain better.
The magnatron puts out microwave energy. Under normal conditions this energy would be absorbed by the food and cause molecules in the food to become excited and move around. Moving around would cause them to hit one another, causing heat and friction that heats and cooks the food.
When you put metal in the microwave, the microwave energy is reflected by the metal instead of being absorbed and looks for the easiest path to ground, most likely the wall of the microwave which itself is grounded. This causes a rapid transfer of energy and a visible arc
How was that?
Woodmizer LT-10 10hp
Epilog Mini 18 Laser Engraver with rotary axis
Digital Wood Carver CNC Machine
6 x 10 dump trailer
Grizzly 15in Spiral Cut Surface Planer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
terrifictimbersllc
Pretty good explanation I can get my  mind around, thanks.  Still wondering where the metal carousel in our microwave  fits in the picture. .
Freedom6178
If you want to see something cool just throw an old junk CD in the micro upside down for about 35 sec or so and watch..  :o :o :o  :D :D :D
------Freedom6178------
Prepare for the unknown by studying how others in the past have coped with the unforeseeable and the unpredictable.
George S. Patton
'12 Mustang, '03 F-250 SD 4x4, Stihl Farm Boss 18"bar, '09 Arctic Cat 550 TRV EFI
petefrom bearswamp
I have a small homemade DH kiln which works well, but has eaten 2 dehumidifiers so far.
Something about the acids in the wood.
I have only dried about 2 mbf so far so it is fairly expensive to use considering replacing the dehum machines
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
SPIKER
If using the Microwave to dry, use the DEFROST setting as that puts out marginal power and cycles that high low to let food defrost without burning it at spots.
longer cycle time with lower settings for sure.   One of the famous wood carvers uses a home made microwave to dry some of his creations.   It holds large trees that had been carved into a lot of interesting shapes.
The food dehydrator air movement might move too much air and dry causing cracks would be my fear but small ones might work.
mark
I'm looking for help all the shrinks have given up on me :o
