Urban Lumber
Started by Grandedog, August 06, 2014, 05:37:38 PM
Grandedog
     Howdy,
   Probably been a while since there was mill dust in this part of Portland.
Regards
Gregg
http://youtu.be/piF1UYx4Xwg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
Dave Shepard
Great video! Keep those trees out of the landfill. Their "arborist" was a bit sketchy starting the saw with the tip in the dirt. Must be good at sharpening. :D
Ron Scott
~Ron
Silvanus
"There are some who can live without wild things and some who cannot."  -AL
Roxie
Very uplifting!  Thank you for sharing that Grandedog!
Say when
scsmith42
Tom's 3638D Baker band mill
Seaman
That was cool, two mills and a KILT!
Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
pine
Thanks. Nice link. Whose LT 50 did not see?
brendonv
All my wood comes from the urban forest. My house and garage is covered with it, shed will be and a timber frame garage. I pull good logs off my jobs and bring them where they will be best used.  Ill even use the bark!
Just milled this wack o logs on sunday. Prob four-five more loads on this job.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
mikeb1079
that vid was very similar to the "urban lumber demo days" that they had in madison a few weeks back.  very cool stuff, glad to see the idea is catching on.  brendonv i wish more tree service folks were like you.  kind of a shame to see so much usable timber being cut up or chipped.
that's why you must play di drum...to blow the big guys mind!
homebuilt 16hp mill
99 wm superhydraulic w/42hp kubota
Good to see the trees being used.
brendonv,nice picture off you topping a tree.
chet
brendonv
What kind of loader ya got on yer trailer?
brendonv
Farma 51d. I bought it ussssssed.  One of the baileys units.
www.VorioTree.com
JohnM
That was great, Gregg!  The guys in the suits on the slabber looked some sharp. :D  Someone put some hours in producing that video, very well done and a great message.
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
woodworker9
Great video and presentation!  I'd love to get my hands on some of those slabs to make furniture out of.
Stephen1
That was great Video, so great to see the movement coming alive. There is so much urban lumber out there to use
Nomad
     Today I contacted our local urban forester about these logs being wasted.
     "I'm curious if ************ makes use of the logs cut from the city's land.  Do they just end up in landfills? Or is ************ following the example of many cities around the country and making use of the wood from these logs?
    I don't believe that healthy trees should be cut down without a good reason.  But the fact is that many hundreds of tons of trees are cut in this city every year.  Some of those would make good saw logs.  If it isn't already being done, the city is missing out on a way to cut costs substantially and possibly even turn a profit."
Here is his response.
"Thank you for contacting us about this issue. The city of ************ actually has an ordinance that prohibits us from removing any tree on the right of way that is alive and healthy. Most of the trees we remove are already dead, or in decline. Almost all have some major defect such as large hollow areas. Very few would be suitable for lumber.
Currently neither the city or our contractors have the type of equipment that would be needed to handle  lumber logs. The trees are always cut into sections  that can be more easily handled. Unfortunately, given the small numbers of trees that would fall into this catagory the economics of it just wouldn't work.
Currently the logs are taken to recycling sites where they are ground into mulch."
     I'm thinking this attitude has a lot of impact on why this idea isn't being pursued here.  And incidentally, it's the largest city by land area in the lower 48.  I'm annoyed. :snowball:
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Tom the Sawyer
Nomad,
Frustrating isn't it.  I, too, have butted heads with municipal employees who dismiss the value of urban timber.  Fortunately, not all of them do.  I have worked with half a dozen communities who have realized the value of their timber, either directly from the value of the lumber, or indirectly from the reduction of costs associated with landfill tipping fees or grinding costs.  We just have to keep plugging away.  Make contact with municipal foresters, state and community foresters, parks managers, etc.  Very soon, they may not have a choice...
There is potentially a very positive movement on the horizon.  The Tree Care Industry Association has proposed some extremely progressive ANSI standards for dealing with urban timber.  If adopted, those who follow the ANSI standards (significant economic factors influencing conformity) will have to consider the highest and best potential use for their urban trees.  Thinking "sawlog" will much more desirable than thinking "chips".
The proposed standard is called ANSI Standard 300, Chapter 11 Urban and Community Timber, or something like that.  I was able to read it on-line last month since there was a public comment period which ended 8/25/14.  Unfortunately, the link no longer works since the comment period has closed but I expect that it will be available once the standard is adopted.  The way I read it, it will enable major steps forward in the effort to assess, value, acquire and provide urban logs for conversion to lumber.
Keep your fingers crossed,
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
WIwoodworker
Why not just offer to pay tree services for the trees they cut down? They're still urban trees. They just come from a different side of the sidewalk. Many are still being cut into firewood and mulch or being wasted. You'll have better luck with people who are trying to make money and reduce their labor costs.
Peterson 9" WPF
IcePick
Ever since I got into logging part-time, my boss from the tree service I work at has implemented quite the urban lumber program.  We hire a guy who works for We-Energies that has a bandsaw to mill our logs. I believe he charges 25 cents a bdft.
We have stacks of dimensional lumber and some pretty cool slabs that have been built into shelves, mantles, tables...
At our office, which is a side by side building, we have even opened up an urban wood lab that is open to the public to see our stuff.  I believe my boss is turning it into a type of co-op for local wood artisans to display their stuff as well.
As far as firewood, we still have our customers, and we will continue our large operation of firewood sales, and we have customers who order mulch every year, so we will continue to tub grind the crap into mulch.
It's nice not to turn EVERYTHING into firewood or chips though.
Trying to support myself and a family working with trees since 1998.
Ron Wenrich
A little late to the discussion, but I'll give you my experience with urban logs.  I did consulting for an outfit that was going to convert urban logs to lumber.  Their problems came from a total lack of knowledge of mills, logs, and product.  Their process was going to be to take urban logs for free.  The alternative was that most of these logs were going to the dump.  Tipping fees are very high, so the savings were put into the arborist's pocket.  The practice quickly filled the yard with logs of poor quality and form.  It was explained to me that you couldn't charge for logs, as then you were classified as a dump.  More red tape.
The biggest problem was tramp metal.  All logs were scanned, but the problem persisted.  It destroyed saws.  The second problem was log size.  Most of the suppliers didn't have equipment big enough to pick up logs of any length.  They ended up with a bunch of logs under 8'.  That ends up costing more to produce.
That's not to say that there isn't a way of using urban logs.  You just have to be a little smarter on how to do it.  You might have to charge a handling or processing fee.  Note:  it's not a tipping fee.  You should also limit who you get logs from.  A reliable source of logs will take care of a lot of problem like length and metal.
You need to have some really good markets for the products.  You'll need several markets.  Some logs are best being made into either mulch or firewood.  You have to keep them out of your lumber supply.  Some logs aren't suited for grade lumber.  Mill those into industrial quality.  Sometimes the rapid growth of urban trees takes away from the appearance of the lumber.
Markets are out there in the urban areas.  The bigger the city, the more the opportunity.  Prices are pretty decent, but so are expenses.  Good labor is hard to find, expensive and has to be trained.  Rent or ownership of land is very high.   Equipment must be compact, productive and versatile.  It also has to be big enough to handle heavy weights, as many logs are big and heavy.  There is good opportunity in secondary processing.
One of the problems that developed is there is a large east coast mulch maker that has their eye on urban logs in big city areas.  They don't like competition, and they have deep pockets.  They're starting to do urban logging.  I was working with another guy last year on developing a working relationship involving milling the good logs, and letting them have the waste and logs that wouldn't make lumber.  They liked the idea, but didn't like to share.
I think there is good opportunity for urban lumber, but it has to be approached from a different aspect.  The video is going for a high end market aspect.  Not every stick is usable for lumber, and not every piece of lumber is usable as flooring, tables or the like.  It's a nice idea to plant in someone's head, but far from reality.
Carson-saws
Ron Wenrich....interesting perspective.
Let the Forest be salvation long before it needs to be
