Gafner MB 411 Mini Skidder
Started by Hrdlx62, November 14, 2014, 02:45:48 PM
0 Members and 15 Guests are viewing this topic.
Hrdlx62
Hello all, new to this sight and would like to know if anyone out there has seen or has any info on a cable skidder a friend of mine just picked up. Its a Gafner MB411 Mini Skidder. The machine is a bit of a basket case and I have been recruited to help put it back together. The engine and trans is out, we got the engine running so that should not be too big of a deal. The problem is the transmission is pretty sick, its partially disassembled and is gonna need major work to get going. Big problem I see is parts as its a Mercedes Benz Unimog unit and I don't think theres gonna be an abundance of spare parts laying around! anyone know of these? Its a pretty neat little machine none the less Hopefully we'll get it back in the woods! Thanks, Joe
coxy
could you put in a tranny out of a small truck like 1/2-1 ton or a little bigger  mybe a NP 540
Hrdlx62,welcome to the forum. Good luck with the skidder.  ;D
lopet
Welcome aboard Hrdlx62
Here is another thread about them.                         http://209.164.108.37/board/index.php?topic=74627.0
It might be a bit challenging to get parts for it. What kinda tranny is in it?
Make sure you know how to fall properly when you fall and as to not hurt anyone around you.
Also remember, it's not the fall what hurts, its the sudden stop. !!
logman81
I have a sales brochures of that machine with all the specs. Would love to see a pic. Welcome aboard!
Precision Firewood & Logging
snowstorm
back in the 70's case dealers also sold unimogs. they put case backhoes on them. also the national guard had some
logman81
That is just such an awesome size, I wish I had one! That would be the ultimate firewood unit ;)
logman81
I'm planning on buying one in the spring if I can convince the guy to sell it.
Hrdlx62
Yes its a pretty neat little machine, firewood and small woodlot logging is the plan. The problem with trying to refit another trans is that the transmission, transfer case and PTO are one unit. Not that it couldn't be done I'm looking into options. I would be nice to just get it back together as it should be. We'll see what happens. I would love to get a hold of the repair manual for the machine if they had one! That sales brochure is great!
logman81
You can have the sales brochure if you want.
SliverPicker
Somewhere around here I have the phone number of a guy who has at least 2 UniMogs in unknown condition.  I will try to locate the number. If I can find it I will PM it to you.
No promises.
Yooper by trade.
SliverPicker
Whatduyaknow! The first place I looked there was the number.
PM sent.
Yooper by trade.
Hrdlx62
Got the engine to run briefly (no cooling system). 1 and 2 cylinders were lazy. Had fuel to all injectors. I pulled the injectors tonight and will have them checked and if I can find an adapter will do a compression test. Transmission is worse than first thought. The output shaft end pilot appears to be broke.
KyLogger
I only work old iron because I secretly have a love affair with my service truck!
Ford_man
The Brochure says it is built with Mercedes components, maybe a dealer may be able to help. I was thinking the tran could b a truck tran. They did & still do build trucks.
splitwood_smiley splitwood_smiley
Holmes
 Some where I heard Mercedes used to build  Unimogs.
Think like a farmer.
Reddog
Do a google search for "unimog 404 parts" and "unimog 406 parts"
Then start calling. Plenty of parts supply for mogs.
Corley5
Gafner's machines were all built with drive train components from other manufacturers.  Their Iron Mules were based on Massey Ferguson and Ford industrial tractors.  Parts for these Minis shouldn't be a problem except for paying the Mercedes Price.
chester_tree _farmah
In most other countries Mercedes are taxi cabs. Just saying. Lol
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
longtime lurker
That's a neat little machine, I've never heard of those.
Hrdlx62
Not making much progress on the transmission. Not a lot of stuff out there, although one outfit has a complete reman unit but the price s not so good. the retrofit option may have to come into play. I pulled the injectors the other night and am having them checked. I have a suspicion that the engine has a blown head gasket. If the injectors check out OK I'll try and find a compression adapter or do a cylinder leak test to pinpoint a head gasket leak. Deer hunting starts Sat. so won't get much done for the next 9 days..........unless I luck out early!!
KyLogger
I want an Iwafuji!! (haven't heard of em either!) Look at the winches.......stupid simple! Wouldn't pull alotta big wood but could probably surprise you. And I would imagine by looking at it that it would be a snap to find parts for and easy to work on.
CountryTrucker76
Quote from: Hrdlx62 on November 20, 2014, 08:42:43 PM
I have one of these Gafner Mini Skidders For sale but it has been converted to a forwarder check out ebay.
