A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
0 Members and 5 Guests are viewing this topic.
Peter Drouin
Quote from: thecfarm on November 10, 2014, 07:30:28 PM
I betcha in a month it won't do that.   ;D
:D :D :D :D :D :D :D :D :D :D No, and you won't see them in the white stuff :D :D
Bruno of NH
Get your long Jon's out for milling this weekend .
Looks like we will need them in NH
Jim/Bruno of NH
mesquite buckeye
Quote from: Peter Drouin on November 03, 2014, 09:13:30 PM
Would you guys call this cherry burls or just a mess? :D :D :D
I'm going to make a $300 bench out of this :D :D :D
With sweep, The (I) on the end is to remind me of Iron in it :D
Looks more like a canker than a burl.
That sweepy ferrocherrry might make a couple of nice live edge fireplace mantles. ;D
Peter Drouin
I put new blades in the edger today. What a job, and the lineup after. Sometimes I wish the blades were two pieces :D
I had to adjust the shaft some.
And move it back.See the nuts and blots.
I use a string to line up the fence.
And John got some claws. :D :D
Dave Shepard
How much were the new blades? I think I need to do mine. Or maybe I just need to peel a layer or two of crud off my feed rollers. :D
John will be walking in style.
Peter Drouin
Quote from: Dave Shepard on December 17, 2014, 10:16:19 PM
I bought them last spring. 125.00 each. Was that you that had trouble with tracking using the fence?
Quote from: WDH on December 18, 2014, 07:16:08 AM
Yes, but now I have to be careful not to break the pallets.
47sawdust
About edger blades-
I sent my WM edger blades to these folks to get re-tipped and the did a superb job.
Mathieu Saw and Tool
Lewiston,Maine
207-783-9087
Mick
Dave Shepard
If I'm just running a board through using both blades, it seems to do just fine. If I have a straight edge against the fence, it walks away, leaving me with a narrow end. Also, one of the blades seems to leave a fuzzy cut once in a while.
Chuck White
I like the new hardware on the front of John.
Nice, don't fall down in between the lugs, so should give great traction.   smiley_thumbsup
Peter Drouin
Quote from: Dave Shepard on December 18, 2014, 03:33:37 PM
You can move the feed roles some, that will help with tracking. I use a square on them. Square to the body of the edger.  The fuzz is a dull blade, If you look you will see a flat spot on the tooth tip.
Peter Drouin
Quote from: 47sawdust on December 18, 2014, 01:37:40 PM
About edger blades-
Lewiston,Maine
207-783-9087
smiley_thumbsup
47sawdust
According to WM if the edger isn't level in both directions you won't have good results.
Mick
Peter Drouin
Quote from: 47sawdust on December 18, 2014, 07:16:12 PM
True.
loggah
I you put a straight edge  like a piece of 1/8" angle iron on the out feed side in alignment with your stationary blade it will hold the wood straight as it feeds thru the edger.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Peter Drouin
Quote from: loggah on December 19, 2014, 07:01:12 PM
The wood goes away from the fence, so if you did that the board will be ¼ to ½" away from the out feed fence.
Peter Drouin
Well, I had time to start finally.
I put a pole at each end, then fill the rest in. :D :D
4 more posts for the other wall, then I can start the roof.  8) 8) 8)
I'm sick Of snow on my wood and my pallets frozen to the ground.
drobertson
I hear there is ocean front property in Arizona :D  sunny and 75°'s year round ;D  the start looks real good, and I'm with you on the snow,  not a big fan either, Pretty stuff, but a pain to work in,
Dave Shepard
That will be really nice when it's done, Peter. Having everything under cover will pay for the effort in short order.
I'm getting pretty aggravated by the snow, too. I've got a bunch of stuff to edge, and processing my slabs can be a pain when they are all stuck together. I've got my eye on a few W24x94 beams 39' long. Three of those in a row ought to be enough. 8)
Snow is no fun,but the rain at 34° is worse.
Peter Drouin
Quote from: Dave Shepard on December 20, 2014, 08:42:26 PM
3 39' yeah, I think so. Can you get a good deal on them?
:christmas:
Quote from: thecfarm on December 20, 2014, 09:26:57 PM
How much snow do you have up there?
:christmas:
Quote from: drobertson on December 20, 2014, 08:32:41 PM
It is a pain, But you have a nice Mill building for your mill so you can cut in bad weather.  Do you have some? I had 12" but with all the rain, I think 2" now.
:christmas:
Dave Shepard
Yeah, I think I can get a good deal, just tell the guy that owns them to bring me his Lull, so I can unload them, and to go back and get them with his trailer truck. :D I don't know what it would cost in the end, but I'm sure it will be manageable. The next trick will be what I'm going to use for the three posts. There are other shorter pieces of steel there, might see if he has something for that. I'm going to have an ~80' opening, and the rest for the edger bay. Plan is to have another 24' extension some day.
Peter,maybe 3-4 inches,with a crust on it from all the rain. I should be in the woods cutting some trees,but I'm playing with some firewood up by the house.
Hang in there Peter, and keep your head up to keep your nose above the snow  :)
Peter Drouin
Quote from: WDH on December 21, 2014, 07:56:21 AM
:D :D :D smiley_thumbsup :christmas:
