Poll 'How many leak free years from your boiler?'
Started by chet, December 24, 2014, 11:32:46 PM
chet
How many leak free years have you gotten from your current or old outdoor boiler?  My mild steel CB has now been in service for 15 years. I run it 365 days a year.
Heatmor has given me 7, so far.  But even if it did start to,it has saved me time and money. I had an indoor one in my other house for more than 20,with no problems at all.
We have a Heatmor, I think we are on the 7th season.
snowstorm
i bought a used taylor 10 yrs ago. no leaks yet. the dealer for them said every one he sold was still going
Dave Shepard
My 6048 is over 8 years old and no leaks. I've only had it running for a couple of months, but no issues with the previous owner.
doctorb
e-2300 is 6 years old.  never had to add water.
Roger2561
This is my 4th season heating with the CB E-Classic 1400; no leaks at the boiler but I did have a small leak at a fitting inside the house where it connects to the flat plate heat exchanger.  A slight tweak with a pipe wrench and all is good.  Roger
Roger
maple flats
I'm answering for my brother's unit. His is now 24 yrs old, but has been repaired a few times. He has re-tubed the unit as well as welded a patch on the bottom and another on the back. At 24 yrs, Installed in the summer of 1990, that's not bad. His is a Taylor Waterstove.
trapper
11 years until my first leak.  small cb.
ckhenshaw4
13 Years on my Heatmor, and no leaks as of yet.      8)
Getting TOO old to "man handle" wood anymore. Looking at building a firewood processor.
VTwoodworker
E-classic 2300 - 2 1/2 years before a defective weld cracked.
I had the welds repaired and reinforced and now on 3 1/2 years since.  Unfortunately Central Boiler and the lifetime warranty on these defects were worthless with the problem.
jcmc
Central Boiler CL-40 installed November 1998 still no leaks Knock on wood!!!!
OneWithWood
The CB 7260 has been in service for ten years now.  No leaks.  It burns about six months per year and yes, we have caused it to boil over a time or two (amazing how hot a fire fueled with shop scraps can get in a very short period of time).  The CL-40 we had before that was in service for 12 years without any issues.
One With Wood
Randy88
wood doctor was 5.5 years old I think the first time, has leaked twice since then and is now 7.5 years old
Farmerjw
Central Boiler, 14 leak free years (no leaks ever).  Replaced it this year with a brand new classic only because it would be the last time I could get a classic.
Premier Bovine Scatologist
firechief
Central Boiler E-2300 leak free for 6th year now.  knock knock knock
userdk
I have a Heatmaster SS. 8 years to date and no problems.
tractorhead9542
Wood Boiler brand. Nothing but a problem! No actual leaks on the boiler itself, but EVERYTHING else has had an issue. 4th season now, I am constantly working on it! Works great when it does, but boy look out when it has a "day". Oddly enough, I still like it. Go figure...
Saws: Stihl 015, 036, MS250 (2), MS362, MS461, MS660. Equipment: Northern 30 ton splitter, Ford 340B, Gehl 3935 skid, 2004 Ford F-350 DRW, and a lot of Allis-Chalmers!
red oaks lumber
no leaks here... i never keep a stove more than 5 yrs though :)
ihookem
I have 6 yrs in when spring time comes. No leaks but my controller went out.
bigbuckhughes
th9542,    What sort of issues have you had w/ your stove?  Just curious.  Am a central boiler owner and just like to be aware of what may go wrong.  No leaks since useing for the last 8-9 seasons
tractorhead9542
bbhughes- This is a Wood Boiler brand. I feel its more of a series of design issues than anything. Starting with the blower had NO shutter. It would empty the firebox out in hours and constantly had boil overs if it was above 40. Had to build a automatic damper/shutter.No stack caused a constant haze around the house. Added a 4' stack and that was done. Hoses on the door pinch, bind, and then leaked. I fabed swivel hyd. hoses and that helped some. Pump tends to aerate when house doesn't call for heat. This is my doing I believe- pump(s) are in basement on a panel for ease of service/swap. Sheetmetal likes to loosen up on the exterior too. Still I have to say I like the full door and octagonal firebox and that's what has kept me from cutting it up...
Hawken50
I've had a woodmaster for 10 years, with the exception of a blower fan going no problems.
