Dovetail Log Cabin
Started by fred in montana, February 07, 2015, 08:22:35 AM
fred in montana
Here are some photos of a cabin I built a couple of years ago. The one we will build during the workshop in June will be a similar size. There are details about the workshop in the services category.
In this first picture you can see the wavy edge. I moved the saw head up and down as I went along cutting the top and bottom edges of the log. This way the chink joints were not all a constant width. I think it looks less manufactured this way.
woodmizer lt15, mf 65 tractor
logdovetailjig.com
fred in montana
logdovetailjig.com
Love it.  There is a very nice, and considerably larger dovetail cabin just around the corner from our place. I admire it every time I go by.
fred in montana
logdovetailjig.com
tule peak timber
Looks cozy, and a welcome camp to come back to after a hike or a hunt.
You should treat yourself to a Logrite cant hook to replace the wood handled one shown. You won't regret it, and the 30" model would be real handy for logs around the mill and the cabin build. Just sayin...
justallan1
That's my next dream. Possibly a bit bigger.
Allan
I love it.  A log cabin bunkhouse is in my dreams.  Hopefully these ole bones will allow me to fulfill that dream.  I looked at trees yesterday.
Peter Drouin
I like it, But to move the blade up and down to get the [look] Why not use a dull blade, Or did you? :D
fred in montana
The idea with moving the blade up and down was to vary the vertical dimension.
logdovetailjig.com
Seems the same effect could be gained by just randomly easing off some of the corners with a draw knife, and not compromise the fit between "logs" with a wavy pattern.
fred in montana
I think the draw knife would work too.
logdovetailjig.com
Is there a way to create the dove tails and have the logs flat against each other, with no chinking space?  I'm having to do some serious rethinking on the cabin I want to build due to the building inspectors requirements.  I have about 180 8-9" average diameter 8ft logs on site. I could build conventional horizontal log. I'd like to flatten the logs on two sides with the woodmizer, and use flat foam compressed between them and log screws to hold them together. Can you still do that with a dove tail corner?
woodworker9
Quote from: Jeff on February 12, 2015, 10:45:01 AM
The short answer is "YES", you can.  You just have to be very accurate with your joinery, cutting the dovetails.  A close friend of mine built his cabin this way in Idaho, and he routed spline grooves between each log for a 1" thick spline.  This spline acts as an alignment aid, as well as keeping the "outside" outside.  He insulated between each layer and over the spline with foam rolled insulation.  The cabin is beautiful, and pretty efficient, too.
Being a professional woodworker, and not a log builder, he took his time, and cut the dovetails by hand with a hand saw, not a chainsaw.  I am personally in awe of seeing dovetails cut accurately with a chainsaw.  I do not think of a chainsaw as an accurate joinery tool, but there are those who are great with one.  I'm more of a handtool guy.
1938farmall
seems like you could save yourself endless heartache by just using a simple "butt & pass" corner with foam & logscrews.
aka oldnorskie
I totally agree. Problem is I have to conform to materials and methods the county inspector will allow. I would much rather do butt and pass as I understand the joint and it would be much easier for me.
cbla
fred in montana that looks amazing!
Here is a LINK to Fred's website discussing chink gap size.
I mentioned to him in a PM about using ΒΌ" and he said OK.  My plan is to use 6X8 Red Oak.
fred in montana
About 25% of my customers build with zero gap. Some even use factory milled logs having a tongue and groove.
When using any dovetail jig, every cut is precise so it works fine.
logdovetailjig.com
fred in montana
logdovetailjig.com
shelbycharger400
Yes, i know of a jig that clamps to the log, and stops are built in so you dont cut into it. Ill have to do some digging. I cant remember the maker. But it was $300-500, .
4x4American
Boy, back in my day..
shelbycharger400
Guess i was way off on $.  Dream dovetail jig .   $800
fred in montana
I built mine for about $50 in about 2 hours and have built three cabins with this set.
logdovetailjig.com
If/when I build, it will be with Fred's jigs.  :)
My first priority is finishing the bedroom on the Cabin Addition, and then hosting a "Chickin Crispin".
