Plaster finish inside of purlins
Started by shinnlinger, February 18, 2015, 07:28:04 PM
shinnlinger
Hello,
I am putting up plaster board between my purlins so that a coat of tinted plaster will work it up and I will be done.  As opposed to taping drywall and painting or cutting in beadboard and trimming.
Shinnlinger
Brian_Weekley
Shinnlinger,
Not sure I follow.  I thought plaster board is the same as drywall?  Are you skim coating the drywall?  How do you deal with seams without taping?
Thanks,
Brian
e aho laula
shinnlinger
Plasterboard absorbs water and allows plaster to stick to it.    My neighbor is a plasterer and can basically come in in one pass and fill the section and be done.   Drywall would require sanding and then painting which would become tedious around the beams.
Shinnlinger
Brian_Weekley
I've never plastered before, but I like it.  Not sanding and painting is a good thing.  Do you do anything special at the plaster-wood interface?  What happens to the plaster when the purlin dries or just moves due to normal seasonal expansion/contraction?  Just wondering if that's a concern?
e aho laula
shinnlinger
It will probably have a bit of a gap but my frame is 7 years old and has been enclosed and heated for a number of years so hopefully its done most of its  shrinking
Shinnlinger
shinnlinger
 Peak is done in the master bedroom.  Looks pretty good to me!
Shinnlinger
fishfighter
That is sweet looking. Anymore pictures of the building?
shinnlinger
Check out my gallery. Few shots there...
Shinnlinger
Brian_Weekley
Looks nice.  Does it take more than one coat of plaster or can he completely finish each section with one coat at a time?
e aho laula
fishfighter
shinnlinger
He basically does them at the same time, but it is technically two coats.  He will lay in a load of mud and then push his scaffold to the next bay and repeat.  Once done he will come back and add a second layer but it is really just random high spots for texture and then roll back to the other bay.  He will then roll back and knock down the high spots to finish it up.  I would say about a half hour for two sections.
Shinnlinger
He certainly earns his keep with those small and tight areas trying to trowel on that coating. But looks like he is doing a good job for you.
Different professionals have different talents.
shinnlinger
He actually likes it because he can do a small area and be done vs having to worry about it setting up too fast.
It is also a great way to get tight to the beams.  He is quite good and can make it much smoother or textured but my wife liked what he I doing so that ended that.
Shinnlinger
Bruno of NH
I like the textured look with the beams IMO .
Nothing like real plaster it's the best .
Looks good Shinn
Jim/Bruno
fishfighter
I agree. Looks real nice. Going to have to check in to this.
Darrel
Quote from: Magicman on February 25, 2015, 10:38:14 PM
Yup! I'd have plaster all over those beams in nothin flat!
1992 LT40HD
shinnlinger
Shinnlinger
Geeg
That blue 3M tape works wonders, Nice job shinnlinger!. I did mine a little different and screwed the drywall on the back side of the osb, same same but different  :laugh:
Finished Product
Retired Airbus 380 Captain. Timberking 2200,  Kioti RX6010PC,  Nyle Kiln KD250, Polaris WV850
so il logger
Tom King
I prefer plaster over drywall dust any day.   Did you use USG Diamond?  Check out my website for some plaster work I've done.
