Bought wheels for new build
Started by sst04, March 05, 2015, 11:27:32 PM
ozarkgem
I see. I could use some of the hydraulic guru's when you are done with them
boscojmb
This will definately be an interesting built to follow.
I like the hydraulically driven bandwheels.  ;D
I am curious about the car engine.
Did you find a good way to mount the hydraulic pump(s) to the engine?
Building or adapting a governor and linkage that will keep consistant speed under a load may be one of the most challanging parts of this build.
I look forward to watching this project unfold.
John B.
Log-Master LM4
sandsawmill14
more than likely you can order a mech gov that will just bolt on if its got a carb if its fuel injected it can still be done but im not familiar my stuff is to old
Joe Hillmann
Quote from: sst04 on March 06, 2015, 02:07:17 PM
There is one thing that I'm not sure of yet, and that is guide wheels.
I cut one v wheel on the lathe to see how hard it would be, fairly easy to do.
But now I'm wondering if I would need a cam follower or something to make sure sawhead can't lift off the track??
Had planned on angle iron welded to top of 2x6 tubing, but I may rethink this if anyone thinks the blade could make the head rise off the track?? Or would the weight of sawhead hold it down??
I had the head of my mill tip over when it was running,  it was caused by a broken lift cable.  It was dangerous and probably damaged a couple hundred dollars worth of parts.  I would recommend something wrapped around the beam to keep the head from being able to tip.
https://forestryforum.com/board/index.php/topic,76459.msg1159944.html#msg1159944
sst04
Quote from: boscojmb on March 08, 2015, 11:38:27 PM
Probably a short driveshaft from crank to pumps, one off front and rear. Ill just make an adapter to bolt to flywheel and crank pully.
As far as governor, a cruise control should work.
I have the band wheels now, they are browning brand, so if anyone looking for some they are on clearence at grainger, get them before they are gone! 3x610 part #.
