Wide plank flooring...how wide can I go?
Started by lshobie, December 26, 2015, 10:08:33 PM
lshobie
I just saved this pine from being turned into firewood, it's 38 inches at the butt, 50 feet long, the top blew off it 2 years ago and it died and remained standing for until a couple of weeks ago.  Some greying and pink spots in the wood and I'm fine with that.  Seems to be fairly dry with no gum to be found - not like cutting a fresh one thats for sure.
So I'm thinking of using some of this for flooring in my cabins.....how wide can I go?  Ive got access to a 24 inch planer and possibly a 30 inch cabinetry finish sander, my friend thinks at 30 inches there will be too much warping and cupping but Im thinking that it's well on its way to drying and another 4 -6 months outside in the stack and it should be good.  What's the widest planking youve seen on a floor?  any fastening recommendations?
Cheers.
John Deere 440 Skidder, C5 Treefarmer,  Metavic Forwarder, Massey 2500 Forklift, Hyundai HL730 Wheel Loader, Woodmizer LT40, Valley Edger,  Alaskan Mill, Huskys, Stihls, and echos.
POSTON WIDEHEAD
That was a healthy tree.  :)
Personally I would not make my flooring over 6 inches wide. But thats just me.
Some other folks may give you better advice. Good post.  smiley_thumbsup
hopm
York Woodwright
The pine planking in our farmhouse, which was built before Canada became a country, measures up to 22 inches wide. The gaps between boards allow you to see what's happening on the other floor. If you don't mind a little cupping along with loss of privacy, you can go as wide as you want.  :)
I'm still learning how to use my WM LT40HD. This is an avocation, not a vocation -- not as pecunious as medicine, but a lot more fun!
Rando
A friend has some floors 2' or so. He put them down with screws so he could take them out and move the boards closer to get rid of the gaps.
Kind of makes you look twice when you first see them being that wide.
johnnyllama
I installed 11" pine over radiant heat. I was told it wouldn't work, too much spliting and cupping. 18 years later it's still pretty flat, no splits or checks. BUT it moves every season a bit, with about 1/8" gaps, which I'm fine with, I wanted it to look old anyway and old farmhouse floors around here with true wide plank floors have big gaps. It depends on what look you want. 30" would be too much seasonal movement to not split in my opinion but 12-16" would be acceptable as long as you are willing to accept the joints and ocassional checks. I put mine down with cut 2 1/2" nails at every joist, 2 and 3 nails alternating joists.
Turner Bandmill, NH35 tractor, Stihl & Husky misc. saws, Mini-excavator, 24" planer, 8" jointer, tilting shaper, lathe, sliding table saw, widebelt sander, Beautiful hardworking wife, 2 dogs, 2 cats, 23 llamas in training to pull logs!!!
fishfighter
I think if you saw them at 6/4, that extra would help out checking and cupping and I wouldn't go over 16" wide.
woodman58
I install hardwood floors for a real job. Anything over 5" should be glued and nailed down. This is the recommendation from the National hardwood flooring Association. I have seen 3" wood cup in the right conditions. Good Luck.
i LOVE THE SMELL OF SAW DUST IN THE MORNING.
Timberking 2200
snowshoveler
8 or 10 years ago I had a friend saw me out some nice pine.
We got 22 and 24 inch boards out of it. 12 feet long
Very few if any knots in any of it.
It never buckled bowed or twisted.
Can't say if it shrank much because I still have it stored overhead in a building.
I did not take as good care of it as I should have but I must say I think the knots are what twists and warps the wider boards.
Regards Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
I used  4", 6", 8", & 10" Pine in the Cabin Addition and 6" & 8" Ash in the Bedroom project.  All was T&G and surface nailed.  So far, no issues.
Ox
I grew up in an old house built in the 1830s or so.  There were several local sawmills run by cricks (creeks) in those days.  Wide, thick boards for flooring with large gaps.  Some are pushing the 24" mark awful hard.  Ironically, the widest boards aren't cupped but some of the narrower ones are.  I suppose it's likely because of the part of the tree they sawed them from.  In a cabin I'd go as wide as they mill out at and enjoy the rustic building practices.   :)
Here is a topic you might find interesting on a visit to a place where the floor boards were up to 22" wide.
https://forestryforum.com/board/index.php/topic,1321.0.html
Dave Shepard
It's white pine, go as wide as you can. If a wide board cups in drying, cut it in half, and it will still be wide. :D That log hasn't dried much.
Rando
Saw my friend today. He said his are 30" and 32" and they do have seasonal gaps but he did not mention any cupping or splitting.
Tree Dan
I would mill them all 8" x 4/4.
The floor will look great.
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
Ljohnsaw
I plan on just using 8/4 x 8" T&G - no sub floor.
Joey Grimes
A old rule of thumb I've heard was increase 1 inch in thickness for every 12 inch in width.
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Joey
Not sure where or why that rule of thumb would apply to flooring board widths, but maybe someone knows.
Ox
Quote from: Jeff on December 27, 2015, 10:06:41 AM
Even in the pictures, which as you said rarely do things justice, that's a really nice floor.  I love the looks of natural wood buildings with different species all mixed together for contrast.  Warms the soul somehow.
JBlain
I think the width maximum has as much or maybe more to do with the growth rate and stress of the tree as anything.  My wife and I own an old ice house, now a 2 unit apartment building, that used to be along a canal that is all beam and post with brick in between for insulation.  It is a tank of a place.  The floors in the attic are 12-20+ inch wide and show no cupping with only cut nails holding them down.  I got a close look at the growth rings and I estimate 1 to 1.5 inches of diameter growth per 10 years.  Very tight and slow grown = stability imo.  I don't know the age of the pine you cut but I would factor that into my calculations.
Josh
Jim_Wahl
I think you will find that the moisture content has not changed much, if at all since it was alive, even if the sap has "set".
1997 Peterson 9" WPF since 1998
2004 Baker 3667D since 2014
Cooks Catclaw sharpener and setter
I am from Iowa, but I seem fine.
Peder McElroy
I have 14 inch #2 pine for the last 20 years and all is good.
Greyhound
Cool logs.  That will be a fun project.  We did our floors from some old red oak, up to 28" diameter and 8-12 ft long.  We chose random width 6", 4" and 3" wide planks to maximize the yield.  It came out great.  However, I have seen some wider softwood floors.  As above, the wider you go, the more gaps and cupping you will have to deal with.  That's your call.  From my experience, I will offer this advice. Fine a custom millwork shop and have them mill the rough lumber into T&G planks.  It's very inexpensive and they have the right machinery to do it faster and more accurately than you can do.  It is money well spent.  FWIW, I used Horstcraft Millworks in Richfield, PA.  They did a great job.
kensfarm
How far apart is the beam spacing..  I spaced barn floor beams 24inch.. 6/4 would be thick enough for 24inch beams.. plus your doing T&G.  I'm using 6-12 inch widths.. no T&G.. mounted w/ predrilled, countersunk lag bolts w/ washers.  Beams & boards are both white oak.  It was 48 spaced w/ sticks and tin on it before.. you really had to watch your step.. but good enough for square bails.
When I first moved into my log cabin farm house.. the living room had no subfloor.. the flooring was T&G.  When you stepped on a 4inch board.. you could feel it bow down.. you didn't feel the flex on the wider boards.  So now I have a subfloor.. still haven't put the finished floor in yet..  I'm wanting to use wide boards.  I tested some adhesive on a bathroom wood floor.. hasn't budged.  I think I'll have to tear it up now to fix a broken water line(got frozen).. it only has hot water now.. but makes the throne toasty warm if you pre-flush.. kinda nice in the winter.
Greyhound that is one beautiful floor you have.
lshobie
That's some great info thanks guys!  I like the T and G idea and will do that.  We have enough that we can easily cut 5/4 or thinker if we need to.
