Old school vs electric hand planers
Started by Jaket123, January 09, 2016, 08:07:48 PM
Jaket123
Anyone on here have any experience with electric planers? The hand held type? If so any input would help I'm considering buying one. But debating if I should go with standard planes or go modern with the electric plane. Thanks guys!
Just cause...
gfadvm
Those power planers are great for planing a door edge to fit but not so good for trying to flatten a panel or slab.
Jaket123
Ok that's what I was wondering. Cause I know from time to time when I glue up a table top or something I'll have a board that's a little off and thought it might save some time Over a std plane.
Just cause...
starmac
Not a lot of experience with them, but what I found was if you were planing something narrower than the bladed, in my case 3 inches, it does a nice job. If you try to make another pass on something wider, it just doesn't work, or at least I haven't found a way to make it work. I have been told it will do a better job on wider pieces if you grind the corners of the blades to a rounded edge, but haven't tried that.
Darrel
The electric plane will only be marginally faster than a good sharp well tuned hand plane and it won't do as nice a job.  Add on top of that fact that the electric makes dust and a heluva lot of noise and I'll take a hand plane any day, even for a door edge.
1992 LT40HD
tule peak timber
We use a power planer A LOT to flatten very large slabs prior to sanding. An indispensable tool ! Rob
Darrel
Quote from: tule peak timber on January 09, 2016, 08:58:34 PM
Rob, that isn't my experience, sadly, I wish it was.  Maybe I haven't used the right power planer or maybe I just don't know how to use it.  I have some large black oak slabs that need to be surfaced and am not particularly looking forward to the workout.
1992 LT40HD
Bruno of NH
They make large hand held power planes .
Timber framers use them a lot .
I bet Rob has a very nice Feestool .
Bruno
Darrel
I'll try again and do a bit more research and if I find something that'll change my experience I'll buy it, Jaket123 probably would too.  Eventually I'd like to get a 42" planer but I haven't made that much money yet.
1992 LT40HD
tule peak timber
Yes A Fesstool . Some pics of slabs we planed with the Fessfool tool.
  One of the pics is a matched set of Black oak slabs. Three common ways to flatten material; slake by sawmill, wide belt sander, or electric planer. Once you get the hang of it , the electric planer is a potent tool !  Rob
POSTON WIDEHEAD
I could floor my trailer with 1 slab.  :)
tule peak timber
Man ,,,must be a really nice trailer !  :D
Bruno of NH
Makita makes a wide hand held power planer that work well .
Bruno
I have a fairly new Porter-Cable planer.  It has a couple of uses for rough work but mostly a junk tool.  Could have got something in the same class from Harbor Freight.
I bet the Festool planer is sweet and well worth the money.  Seeing Rob's pictures makes me want one bad now.
gfadvm
Anyone have a video or a link to one flattening a slab with a hand held power planer? I need to learn their technique!!!  I wrecked a benchtop with a power planer (and it only took a few minutes).
tule peak timber
A single frame video of how to rub the planer. Cheers Rob
Darrel
Quote from: tule peak timber on January 09, 2016, 10:53:04 PM
Now this I find very helpful!  Look out black oak, here I come!
1992 LT40HD
Clark
I've used a DeWalt electric planer and enjoy using the my old Stanley planes also. I would say the electric version is good for removing lots of material quickly. It produces shavings, not dust, so cleanup can be pretty easy.
I don't have the need for a Festool planer but I'm sure it can do a better job than the DeWalt. If you've got access to the "common" tool brands I would leave the more detailed work for the old fashioned plane.
Clark
SAF Certified Forester
ScottAR
I have a Bosch and use it quite a bit for finish carpentry.  They are amazing for fitting doors and working to scribed lines.   The real trick to using one is take a smaller bite than you think you should.
Many try to use them like a belt sander but planers remove material much faster so light cuts are best.  You can always make another light pass.
When fitting doors I set the depth of cut on 1/16" or 1/32" usually and count my passes to know where I'm at.  For flattening, start with the smallest depth of cut and see what happens.  Mine starts at 1/32th.
I like the bosch I have.  The exhaust can be directed to either side by flipping a tab.  Small detail but nice as sometimes you need to change positions and redirect so it doesn't fill your pants pocket with chips.
Scott
"There is much that I need to do, even more that I want to do, and even less that I can do."
[Magicman]
OffGrid973
I love the one frame video...my HF planer and I never got along but I will try this complex diagram of left, right, up and see what is was missing. Last time I went electric I had lots of single passes with edges that needed to be flattened, this looks like a better method.
Your Fellow Woodworker,
- Off Grid
Rob,
Does the pooch come with the instructions?  :D
Kbeitz
I got two of them and I love them both. I think they are only good for rapid removal
of a lot of wood real fast. I agree about  taking a smaller bite than you think you should.
Then finish up with a belt sander. to large of a bite will leave deep valleys.
Love machine shop work
and Wood work shop work
And now a saw mill work
21incher
I have a Bosch that works good. I originally bought it to level the face of a 4' x 30'  landscape wall I built with PT timbers that was uneven after drying and warping. One thing to remember is they work like a planer with one shoe offset, where a hand plane has a flat bottom with the blade exposed so it is easy to make a gouge if you try to take a big cut. :)
Hilltop366
Worked at a boat shop for a short time 20 something years ago, on beams we used a 7" disc sander after the electric planer. Worked really well if you kept moving, it did make a lot of dust though. I should add that this was to prepare the beams for paint on a fishing boat not a fancy pleasure craft.
lowpolyjoe
Great thread!
I bought a harbor freight electric hand plane a few years back and ripped it apart with plans to attach it to a jig similar to a router flattening jig.  I started on the project but it didn't go well and I threw all the parts back in a box... which I may have thrown out by now.  Those are the kind of chances you can take when you march into HF with a 25% off coupon  :D
