Non-Splitting Leveling Boards
Started by Magicman, February 08, 2016, 08:22:34 PM
I have been using SYP 2' & 4' long 2X10's for leveling boards for both the sawmill and camper, but after a period of time they split and need replacing.  Of course I have Pecan, Hickory, Elm, Sweetgum, Hackberry and whatever else available for sawing.
They would be subject to being wet as well as drying out.  My question is which species would be the best for leveling boards?
1ruralmailman
if it was me,and i had it available locust would be my choice.wont matter if its outdoors,and is tough as nails as it gets older.
goose63
MM you hates sweetgum why not use that
goose
thank you to all the vets
Black Locust would not rot, but it splits easily.
I would go with a spiral grain wood like sweetgum.  Has spiral grain that resists splitting.  Also plentiful and easy to replace if it gets rotten.  You also have plenty of it.  If you don't keep your head turned, it will sprout up behind your back  :D.
    I have several red oak boards about 12-14" X 8" X2" long I use under the pads on the mill and they seem to be holding up pretty good. I know not in your listed available woods but the next time you come across some might think about setting a few of them aside.
   Until then I agree with the spiral/cross grain woods like sweetgum.
Yes, I have an abundance of Red Oak and also Walnut and Cherry that I could use.  ;D
sandsawmill14
white oak/ post oak will last the longest i would think. its what we use for bridges and trailer floors :)
I am not concerned with them rotting, just splitting.
sandsawmill14
that w/o is pretty hard to split especially if it is out of the 2nd cut with some knots to curl the grain :)
post oak is hard to split too i had 2 2 1/2 x 12s we used for trailer ramps for years and never had a problem other than the weight :o
Percy
You look tough for 72. How about small cement patio stones?? Never rot, hopefully never split, just kinda heavy...that where the tuff part comes in....
blackfoot griz
Quote from: Percy on February 09, 2016, 12:50:32 AM
MM,
He has some good points! Thanks for the laugh Percy!
Peter Drouin
If you're going to keep the pads for the next job cut 1" 12"x12", put them in opposing grain patten and screw together.
Skip
Red elm ,best trailer decking there is, some old barns around here have red elm floors tough stuff . My second choice would be yellow locust
drobertson
White oak would be my choice,  stay away from the center cuts of course, or just laminate some plywood pieces,
21incher
Make a sandwich with 3/4 pressure treated plywood and they will never split or rot. I also have a batch of 12" x 12" and 6" x 6" pt plywood squares to use under the tongue. :)
I do not have Post Oak and no White Oak that I would be willing to fell.  I will be sawing some concrete form boards from Red Oak soon, so that may be the easiest thing to do.  I am almost scrapping that idea as I type because of weight.
My mind keeps going to Sweetgum if I can dry it without it cupping.  It should be lighter.
sealark37
Heavy equipment mechanics prefer sweet gum and/or elm for blocking that resists splitting.  If you want your boards to resist moisture damage, coat with tung oil or polyurethane.    Regards, Clark
Kbeitz
I coat boards with a 50/50 deisel and tar mix... Works great.
Love machine shop work
and Wood work shop work
And now a saw mill work
Add some steel pads on the levelers to make a larger area in contact with the leveling boards to lessen the splitting.
Then use whatever is at hand.    just a thought without being there and up close to the problem ;)
As per Wood-Mizer instructions, on sloping ground, the downhill side (wheel) is pulled up onto boards for the initial leveling.  2X10's give you some flotation and prevents the boards from disappearing into soft ground.  Of course this wider board also is more prone to split with the weight in the center.  While sawing a large job, there is some sawmill movement and the tire can partially walk off of a narrow board, but I do also carry a couple of 2' long 2X6'S.  2X6's are much less prone to split.  It is all a trade off.
I also occasionally drive off and leave a sawdust covered board.  Several times I have gone back later to a repeat customer and found a "runaway" board.
