A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
Bruno of NH
It does splinter a lot and gives some nice ones to the hands and fingers
Peter Drouin
Can you believe it, First day of the year and look at what drives in.
Some nice W Pine and hemlock to start the year. ;D
With all the ice and snow it can be a challenge piling logs.
With the holidays just about over I guess it's back sawing :new_year:
Dave Shepard
I am 100℅ positive that log clamps were invented in the winter after a dusting of snow.
4x4American
Looking good...frozen logs have anmind of their own, piling them can be a chore.  I gotta truck and pup of beech coming this week and maybe a straight truck of pine
Boy, back in my day..
Bruno of NH
4x4
Do you cut ties or mats with the beech ?
Pine Man gets Pine on the 1st day of the year.  Very appropriate  ;D.  They (I) don't call you Pine Man for nothing  ;).
69bronco
Doug, that beech is some slippery when it's froze! Bad enough when it's not.. Dropped an interesting red oak this afternoon, standing dead 32" butt. Not sure what to do with it but I've got a new box of 4degree Kascos from member Cutting Edge I'm itching to try!
4x4American
Bruno, I get the beech for ties and pallet lumber.
Bronco, that is a gnarly red oak!
Got a call earlier today have another straigh truck of beech coming later in the week.  Might also get a straight truck load of pine in to saw into dimensional lumber for the logger.  Got three trailers in my yard that are customers that I need to fill up for their custom orders and got a bunch of little dimensional jobs and a guy interested in a 20x30 shop. So far 2017 looks promising, knock on wood!
Peter Drouin
69bronco, You might have some nice wood in there.  8) :new_year:
Peter Drouin
4x4, That Beech is tough stuff, I was thinking about cutting a bunch into cribbing 7x8x4'.
I get carpenters want to jack up barns and such. I'm thinking any Hardwood will work.
:new_year:
Has anyone else here cut them before?
4x4American
I have a friend with a hydraulic hud-son sawmill, he said he cant cut beech with it, hasnt found the right blade.  but he can cut hard maple no problem.
On the other hand, I can cut beech fine, and have a hard time with hard maple.
I think beech makes some nice lumber and is an under utilized wood.  It makes for great firewood
Peter Drouin
4x4 it is good firewood, I have made grade stakes with it before.
TheBusyBeaver
that's going to be quite a payday when that's done. also neat idea on the log mover. wish I had a hydraulic mill.. LT15 is all manual
Jim_Rogers
 :new_year: back to you Peter
Peter Drouin
This is how I clean the groove, I flip the auto start, then turn the key, then flip the key off when the brake is off.
With the blade off I can spin the drive wheel. I use my pocket knife with a flat screwdriver end in the wheel and the other end up against the shroud.
Gets all the stuff out.
And while I have the b57 off I use the shroud to scrape the gunk off ;D
Works well for me.
Cutting frozen Hemlock. 8) 8)
Peter Drouin
Had a customer bring in some logs for me to cut for him.
Had a log too big. Told him to cut it in ½.
All was going good making 2x10x16, Hemlock.  Not too hot out, nice day.
Then it happens, One of the pump stop working. :o :o
Has power, makes a lot of noise. I have new brushes coming from WM.
So I took off the wire off the junk pump and will use one till I get the parts.
Dose that make my 40 not a supper now. :D :D :D :D
Just got an order for 1200 LF of 5/4x 4" R Oak and down to one pump.
Always something :D :D :D
paul case
It was warmer there than it was here yesterday. :(
PC
pc
You have to plug the filler hole in the non working pump, but you knew that already.    ;D
Peter Drouin
Quote from: Magicman on January 06, 2017, 08:42:48 AM
I did that
And the oil came out the running pump.
I found a set of new brushes I'm putting in. The motor is downstairs waiting for me to get off the forum. ;D
Peter Drouin
What do you think Magicman?
It did smell a little burnt. :o :D
I cleend it up some, Looks ok,
I have new bruches here and more comeing with some seals.
But like a dumb a$$ yankee that I am ;D
I did not include the bracket ring that holds the brushes in place with the order.
I don't think I can fix the old one,
Mill will be down for awile.
4x4American
Oh boy...at how many hours do you start stocking these on the shelf?
Yup, that brush rack assembly is toast in more ways than one and you will be fortunate if there is not a burnt winding somewhere.  The armature really needs chucking up in a lathe and dressing that commutator and polishing.  That certainly would help the brushes to make better contact.
Is the other hydraulic motor the same age?  If so, now would be the time to rebuild them both.
Bandmill Bandit
I have a local supplier that has the stuff in stock so I don't have to keep them on the shelf.
Also I dont wait for mine to go. A simple load/draw test every 200 ish hours will tell you when to swap em out. The motors should be cleaned at least every 500 hours or once a year or so any way just as a part of a good house keep procedures IMHO. I have not had a set crater yet and swapped the original pump motor brushes etc when I added the second pump 1100 hrs ago. Have done 1 cleaning since with second due this spring.
Most of you will be aware that I up sized ALL my  motor load circuits to #8 stranded copper when I added the second pump with the pumps on 2 OO welding cable from the batteries. ALL connections silver soldered and shrink tubed as required.
Peter Drouin
I did all the brushes in the 2 pumps last Feb. If you look the oil got in there and did a nasty. :D :D
The new seal I put in the last time.
This is the trouble maker.
Chuck White
Ah Ha, another use for roofing screws Peter!
I like it!
