A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
paul case
Exactly.
Nice logs Peter.
Why do you say that those logs are a little big for stringers?
PC
pc
Peter Drouin
The builder was talking 6", Most are 8 to10" All the old barns here are 4 or 5".
Just to hold the 1" boards up between the rafters.
paul case
Wow. I guess I am some kinda dumb on what you are talking about. I think I know but a picture would settle me for sure.
PC
pc
4x4American
I'm lost too..to me, a purlin is a nailer that sits on top of the rafters to nail tin too.  Maybe you're just 2 facing them for him?
Boy, back in my day..
Peter Drouin
The roof beams from the top of the wall to the ridge are 12' apart, the purlins go left to right 4' on center then they lay 1" on top. The purlins will have one face cut flat, roof side. When you stand inside and look up you will see the round 3 faces.
I don't have a pic,
4x4American
Bruno of NH
It's popular in log home building too
3 round sides one flat that the boards nail to
Maybe this will help.  You can see the purlin supported on each end.  It spans across to the other side and supports the rafters:  LINK
paul case
Got it.
The problem is that I hear the roof nailers called purlins when the rafters are spread apart. Not too uncommon for wood barn structures here to only have a truss every 8 or 10 feet and 2x4 on edge between or on top of them for nailers/purlins. Red iron barns often have a 20' stretch.
That is here and we have 18'' of snow every so often.
PC
pc
paul case
Quote from: 4x4American on April 28, 2017, 06:28:17 AM
True, Paul I love your setup.  How come you don't make a bigger opening?
We try the door opening every time we saw 12' logs. Just not very often for us. 8'8'' and 10'6'' are normal sizes for us.
I didn't want to hijack Peter's thread, but this has been fun HUH?
PC
pc
Dave Shepard
Magicman, that is a purlin plate, which runs the entire length of the building and supports the rafters mid-span. What Peter is describing is a principal rafter, commin purlin roof. There are four principal rafters, often as part of a truss, and then short purlins that run between the rafters.
And then we call the ~14½" blocks between our studs, "purlins".  Maybe they are or maybe it's local?
Dave Shepard
There are regionalisms for sure,  but we are also dealing with the difference between conventional framing and timber framing. Not everything translates.
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
redprospector
One thing I've learned about Construction is that what you call any particular component depends so where you're standing on this globe, and what you're building.
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
sandsawmill14
Quote from: Kbeitz on April 29, 2017, 01:02:58 PM
this is the way i was taught  :)
its called lath on a stick building where the rafters are 16 or 24 centers and when they are 1x4 or 1x6 nailed down flat :)  around here the most common use of purlins ( as far as the name ) is on metal buildings and are set 5' apart :)
around here the blocks between the studs/floor joists that mm described are called hobbles it is amazing how different it can be from one area to the next :)
Chuck White
Here, we simply call purlins "roof boards"!
grouch
Kbeitz: Put those on the walls and they become girts. :)
Dave Shepard
 I'm cutting a timber frame, too.  Loads four and five today.  My yard is officially plogged.
Peter Drouin
PC
All are welcome to post all they want in a day cutting wood
Dave you have some long ones there.  :o :o
Can you show some pics of you cutting some?
Last load today.
Quote from: redprospector on April 29, 2017, 01:56:56 PM
Kinda like common names for trees.
OlJarhead
Man you guys make me feel like a slacker with all those logs!
Peter Drouin
Quote from: OlJarhead on May 02, 2017, 01:56:27 PM
My logs are in one place, your logs are in a different spot is all.  ;D
We all see the work you do and slacker is not what comes to mind.
Llke you I cut on the road too. [With all it's avengers]  :D ;)
Now i'm in one spot and liking it.
Had a Friend stop by to say Hi.
4x4 and I had a good visit.
Said he just delivered some Maple down the street. :D
paul case
Well I see ya got a tool in his hand but no evidence of any work since there isnt a log anywhere in that picture?
PC
pc
4x4American
Man, look at how handsome that guy on the left is  :D
I wish I could have visited for longer, seems like we could go on for hours and never hit the same subject twice.
People, the place is looking good, I had to do a RFFSVV (Randomized-Forestry-Forum-Sawdust-Verification-Visit) to make sure Peter is fulfilling his sawdust inoculation quota.  I'm happy to report he passed the test with flying colors.  We also searched the place for grits and could find not one grit.  And we knew we were in the great white north as we saw snow on top of Killington yet as we passed by.
I was happy to deliver some hard maple lumber to his neighbor :D :D
