centering logs on the loader arms
Started by 47sawdust, June 28, 2017, 08:53:05 AM
47sawdust
I'm looking for an old thread that featured a way to center logs on the loading arms.It had a set of rollers to move a log back and forth to position it.Any help would be appreciated.
Thanks,Mick
Mick
Chuck White
Mick, I'm not positive, but I think Peter Drouin made one.
Maybe PM him for further info!
Crusarius
Pretty sure I saw that mod in the sawmill mod thread.
47sawdust
Crusarius,Happy Birthday! You and Chuck were right on the money.It was Peter's creation and it was in the ''sawmill mods'' thread,post #774.
Thanks to Peter as well.
Best regards,Mick
Mick
Peter Drouin
larrydown60
I also saw it on the saw mill mods section
Chuck White
Just in case some of you don't understand this thread!
https://forestryforum.com/gallery/albums/userpics/22511/DSCN2410.JPG
The log is rolled onto the wheels, then it can easily be moved laterally!
Crusarius
Glad I could help. Thanx for the bday wishes.
Peter Drouin
I still have it and would use it if I didn't have John.
It did get hooked sometimes. :D :D
bandmiller2
A handy device but a handier one is careful loading on the deck. I make minor corrections on the deck with a peavey moving one end ahead of the other before I roll the log on the mill. Maybe a roller bolted to each lift arm would be handiest. Frank C.
Sixacresand
The roller deal would be very handy when the milled is setup next to a pile of uncentered logs.  I have drag them back or forth with a winch or come along, of course at an hourly rate.
It always amazed me that a tractor with all hydraulics and power steering in the world, an customer/operator could not understand the need to center the logs.
For myself, I bring logs to the mill with a log arch and center them with mill arms before I drop them.
terrifictimbersllc
Putting a single runner like a pole or 4x4 from the logs to the center of the loading arms can help make it easy to manually steer logs one way or the other.
