A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
Peter Drouin
The sweetgum up here cuts nice and straight. :D
Southside
Oh it cuts nice and straight here too....
Peter Drouin
Just kidding Southside, No sweet up here . Maybe someone can tell us how far north it goes?
Sixacresand
I will be going with the Pine instead of sweet gum.  Gum comes "ALIVE" when milled.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
POSTON WIDEHEAD
Quote from: Peter Drouin on January 06, 2018, 07:37:51 AM
About as far as Grits.  :D
47sawdust
No sweet gum,but poplar will sometimes follow you down the log when sawing.
Mick
POSTON WIDEHEAD
Quote from: 47sawdust on January 07, 2018, 10:49:27 AM
Sometimes a Sweet Gum or stressed Poplar board will load itself on the trailer.  :D
paul case
IF that happens do you still charge for loading?
$300?
PC
pc
POSTON WIDEHEAD
Quote from: paul case on January 07, 2018, 03:34:58 PM
$300?
PC
Yes....the more stress in the wood the less stress for me.  ;D
Peter,
   I can tell you sweetgum does not grow up this far. The few trees I have seen in WV were planted and not naturally occurring. I see it in Charlotte NC 200 miles south and maybe half way between. We had tons of it in Fla where I grew up.
   I remember seeing the leaf in a medical display in Ulaanbataar, the capital of Mongolia, while I passing through there after leaving a project down in the Gobi desert so evidently it grows there and has some medical applications.
   FWIW - A type of Chinaberry tree grows in Saudi Araibia and other parts of the mideast and is called a Neem tree. It is also used for some local medicines and teas and such over there. (Dad said hogs down in central Fla where he was raised would starve to death if there was a chinaberry tree around because they sit under it all day long waiting for a berry to fall then fighting over it when it did fall rather than getting out and foraging for readily available food.)
Peter Drouin
Darrel
Had a dog once that would sit all day under the persimmon tree when the 'simons were ripe.
1992 LT40HD
Southside
I have seen some decent sized sweet gum in southern Joisey.  Maybe it's the winter low that determines how far north it will grow as that area is pretty mild.
YellowHammer
Quote from: Darrel on January 07, 2018, 11:44:30 PM
I bet he was regular. :D :D :D
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Bruno of NH
Peter
My sweet gum saws straight as an arrow over here too ;)
Bruno
Slingshot
   My father-in-law told me about an old farmer back in the day who
cut down a gum tree and had it milled into boards that he used for
a farm wagon bed and when the boards dried out the wagon twisted
so bad that only one wheel was left sitting on the ground.  ::)
____________________________________
hopm
Had a friend who had logs he wanted sawed. Told him to bring them to the mill and I would take care of it for him. When I went to see what he had brought it was all gum. Against my better judgement, I went ahead and sawed it. Wasn't bad at all and I sent it on it's way back to where it had come from. This was about 7 or 8 years ago. I was by his house last week and I noticed a tangled mess of rotting wood. It was the sweet gum. Twisted, bent, and bowed and now rotting too!!
caveman
On another thread WDH was mentioning planting some improved loblolly pines on his place.  I followed the link he posted and the nursery also sells improved sweetgums.  I have been wondering how they improved the sweetgum.  Did they make the gumballs soft so that they do not hurt my bare feet?  Did they precondition the trees to produce logs that will eventually produce high quality, straight boards?  Did they improve the tree's benefit for wildlife?  I have been cogitating on that for a few days now and would appreciate some enlightenment.
Caveman
Darrel
Quote from: Slingshot on January 08, 2018, 01:02:23 PM
If that's how good sweet gum is, I'm going to make some apple boxes from green sweet gum and when the wood dries it will squeeze the cider out of the apples.
No can't do that sweet gum doesn't grow here.
1992 LT40HD
Peter Drouin
One wheel,  :D :D :D :D :D :D :D :D :D :D :D, Thats bad. :D :D :D :D
Kyle,
Improved for fast growth.  And, the faster it grows, the more it twists and warps  :D.
Sixacresand
Quote from: Sixacresand on January 05, 2018, 09:42:58 AM
I will be milling some pine or sweet gum today to get some 3/4 X 8's for vertical siding and doors for a yard building.  If I go with the gum,  I will need to nail it ASAP to minimize warping. And as it dries, the gaps between the boards will be wider, but that is not an issue.
From log to wall in 6 days during some of our coldest days. I milled this pine to 1/2 inch thick X 8 inches wide, kinda to match the beaded masonite siding on the original building.    When it dries, there will be gaps between the boards which is OK for a yard building lean to.  Nancy will paint it anyway when it warms up.  All I lack is putting hinges on the doors.
Peter Drouin
John,
The doors do work a lot better with hinges  :D.
Darrel
Quote from: WDH on January 22, 2018, 08:04:25 AM
John,
Only if you need to open them.  :D
1992 LT40HD
