Band mill Router Plane
Started by Kbeitz, January 25, 2018, 01:09:09 PM
Kbeitz
I ordered two more brass nuts and rod. It will be so much easier
to build using 4 acme rods for lift than two. I got some more done
today. I don't have heat in my weld shop so I run down and weld
up what I need and bring it back up to my home shop. It makes
for more work but I'm wanting to get this done. Looks like I'm
going to get a jump start this year on my summer projects.
Love machine shop work
and Wood work shop work
And now a saw mill work
Kbeitz
I'm going to make a second track for this machine on the barn floor so I can do
4 foot wide table tops with it. All I need to do this is 4 more lengths of channel.
Kbeitz
Working on the top half today. It took most of the day just getting things
squared up and removing BB's.
Kbeitz
Putting the acme rods on today.
justallan1
Looks like a fun build.
I'm eager to see it working, but am wondering about the stability and finish that it will leave.
I do think what you have going there would be a great idea for a sander.
I bought a bowling alley lane polisher awhile back that I was going to turn into a sanding table and you've given me a good idea.
Kbeitz
I'm waiting for two more acme rods to come from E-bay.
Wow this thing is a lot of work.
Kbeitz
Quote from: justallan1 on February 07, 2018, 04:52:40 AM
You better post some pictures. I would like to see that.
I don't think I will have stability problems. This thing
already weights a few hundred pounds and there is
more to add. I was thinking about adding a vertical
cutoff blade to the carriage. Maybe since you brought
it up a sander to.
This is the 2-1/4" router bit I'm going to try.
justallan1
I mean it in the nicest way, but I'd for darned sure try it's maiden voyage with a way smaller cutter than that, just to see what it's going to do.
If it weighs a few hundred pounds and everything is tight it should work if a guy takes his time, but if that thing tries to bite I'd sure want to be somewhere else. :D
Kbeitz
Quote from: justallan1 on February 07, 2018, 08:55:18 PM
Thanks.... I'll let you all know a day in advance before I try it.
It you don't here from me I guess you will know it did not work....
Kbeitz
I googled what was the best bit for the job and I came up with this.
But at  $200.00 a pop I'm going to wait and try what I got.
Bed Skimming Router Bit.
Crusarius
that is weird the cutters are in 2 planes. I really be interested to see what kind of finish that leaves and how it works.
Machine tools are expensive.
Kbeitz
Quote from: Crusarius on February 08, 2018, 07:51:41 AM
If I knew the angles I could machine one. Guess I could guess from
the picture.
I have a similar cutter made by Byrd.  It's a shaper pattern cutter but with the accessory top cutters I can cut an extremely smooth rabbet.  Of course with the shaper spindle it wouldn't work for surfacing.
Years ago their was something made called the Wagner Saf-T-Planer.  It was intended to be used in a drill press to surface boards.  Think it was about 3" diameter.  They can be found on ebay and their are also brand new clones being made.  Unlike a router bit it doesn't require a lot of speed to work.  I've seen one used but have no personal experience in the operation.
Kbeitz
Quote from: Larry on February 08, 2018, 10:33:51 AM
I had one of those. I even sold it on E-bay. There was no way
I was going to hold a board with my hands and use it.
Kbeitz
Anyone one have any recommendations on lube for the acme rod?
I'm thinking spray dry lube of some sort. The acme nuts are yellow
brass. I don't want the rods to rust and I don't want the sawdust
to stick on the rods and cause problems.
tmbrcruiser
I've been using Slick Stuff from Lowes on the mill drive chains and the raise and lower screw. Doesn't seem to draw dust like white spray grease.
Once you get sap in your veins, you will always have sawdust in your pockets.
Peter Drouin
Crusarius
There is a guy here that has an aerosol can with spray graphite lube. it works very well. but it does like to spread with contact.
Kbeitz
Man do I hate working with stainless. Drill speed to fast.
Welded it's self right fast.
Kbeitz
Stainless angle bearing plate. It's the only thing I had that was the right size.
Crusarius
Stainless you need to drill slooooooooow. Oil may help a little.
Have you got any coated bits or cobalt? They work little better to. That one looks like HSS?
Kbeitz
Quote from: Crusarius on February 09, 2018, 10:17:24 AM
All I had was HHS and some cement bits. I had to finish off that hole
with a cement bit. They had a carbide tips. I need to invest in some solid
carbite bits.
This stuff really helps. Ultra Lube High Performance Cutting Tool Lubricant
Ljohnsaw
Quote from: Kbeitz on February 09, 2018, 10:31:29 AM
carbide bits.
What? Wait! Kbeitz doesn't have something! ;)
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Kbeitz
Quote from: ljohnsaw on February 09, 2018, 10:47:20 AM
carbide bits.
Did you ever price cobalt or carbide bits...
Ljohnsaw
I figure you would have found a 5 gallon bucket at the magic junk yard! :)
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
