Daily Fabrication Thread
Started by mike_belben, January 29, 2018, 09:49:04 AM
0 Members and 9 Guests are viewing this topic.
starmac
Hopefully it is something cheap, and the fact it has full power in forward gears gives one hope.
I had to do 3 of those belly pans on 641's that summer on the job in the dirt, with what tools I had in my small service truck, which was lacking for the job, to say the least.
That comalong came apart taking the first one down, I had a warn winch on my pickup and with a little rigging used it to pick it back up and do the other two.
Skeans1
Could be a primary or secondary shuttle as well they'll have o rings and back ups as well, different application but I had a secondary with a broken o ring everything down stream of that circuit gave me issues.
bushmechanic
Well today I had to make an exhaust system for a Perkins out of a 211 Cat excavator. Original parts coming out of the turbo were no longer available from Cat so this is what I came up with.
mike_belben
Praise The Lord
Peter Drouin
woodmaker
Bushmechanic,I love that. I did the same thing years ago with the turbo outlet on an International TD 20c . The 573 v8 would burn the cast iron up from the inside.I used weldable  malable iron  fittings from f.w.webb.
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
51cub
I'm following right along here. You're all giving me alot of inspiration, and alot of work to do come spring and summer
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
Puffergas
Here is my shop heater. Warm up my welding helmet so I get about 10 minutes of welding before it starts to fog up. Keep my water from getting too cold and keep my gloves dry and warm. Keeps the cell phone from freezing up and hard to use.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
Resonator
Wouldn't hurt to up size the smoke pipe too, coming off the turbo, and "Let her breathe". ;)
bushmechanic
My fabrication project for this week is replacing the front bunk on a 1995 Superior log trailer. Got the old bunk cut out and cleaned up ready for a new one. Now if only the darn trucks would stay away so I could finish it.
lopet
Make sure you know how to fall properly when you fall and as to not hurt anyone around you.
Also remember, it's not the fall what hurts, its the sudden stop. !!
2308500
if it was like some of our late nineties trailers, the crossbunk was probably rotted out.   we have a couple b trains that have had most of the bunks replaced over the last couple of years.   it is still cheaper than payments on new stuff,which seems to be made thinner every year :)
bushmechanic
Lopet it was rusted completely out. Owner had it plated in several spots to get by til he got time to replace it. You can see how bad it was by the holes in the bottom of the old bunk.
Oliver05262
  I spent several hours this week--way more than I expected to--fabricating a front end guard for a tractor that a friend expected to use for bush hogging. It came out good; unfortunately on Thursday morning he passed away.  This one's for you, Art.
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
Skeans1
Sorry about your friend.
Only thing different I could see doing is making the guard fold down for service small quick pins to the upright pipe and bolts on the outside for hinges.
GRANITEstateMP
Sorry for the loss of a friend.
What was the green piece of metal on the bottom of the brush gaurd in it's previous life?  Always like a good backstory
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Oliver05262
 I left room behind it so the grille could be taken out to clean the front of the radiator. If you wanted to take the radiator out, you have to take the grille shell off, so you'd have to take the guard off anyway. Next time it comes off, if I have to work on it, I'll slot the bolt holes a bit on the sides. It fit good when I tacked it together, but warped some when it got welded up solid. Hard to figure how much to plan for twist, shrink, or warpage. Oops.
Oliver Durand
It's OK to cry.
Oliver05262
Granite state; that was from a shipping support on a forage harvester from the JD ag dealer where I used to work.
The screen cloth was from the old guy's gravel screen. The pipe used to be part of a sprinkler system. You can't have too much useful scrap iron around, because you never know what you'll need next!
Oliver Durand
It's OK to cry.
lopet
mike_belben
Sorry about your friend.  It goes fast.
Praise The Lord
teakwood
lopet
Thought today was a good day to have the big door open and crawl around on the concrete floor. :)
It's almost as much fun as breaking through the ice with the skidder. :D
mike_belben
Looks good.  Why are the torque arms and hangar angles so different?
Praise The Lord
lopet
No idea, that's the way it was on the pup. Maybe it has to do with the two sets of springs not being identical.
