A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
PAmizerman
Just curious what you guys  feel is a good profit margin? What are you paying for a triaxle load of hemlock and what have you  been getting a board foot for it?
I've been charging $650 a thousand for 1" boards.
Hydraulics everywhere
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
If your costs are one dollar, I would charge two.
Bandmill Bandit
Last prices I was quoted for rough SPF (includes hemlock) in this country was $750 to $800 MBF.
As for a fair margin, cost of goods sold X 2. Make sure you have ALL costs included.
Right now that would put good spruce for me at about $500 to $550/MBF.
I am selling at $650 to 700 which is just a bit under the local market right now.
The cost of my current spruce and pine inventory was the cost of pulling wind downed logs off local acreages which was not real costly for the quality of timber I got.
Peter Drouin
Nice to have logs nearby Bandmill Bandit.
I did an odd cut today, I paving company needed ramps of R, oak.
4'Long, worked ok. :D :D
pineywoods
I cut a few like that to use for wheel chair ramps. Use 2 or 3 side by side to make a solid 3 ft wide ramp.Some 6 or 8 ft long, depending on the amount of rise..
Peter Drouin
That would make a ramp for anything pineywoods, Don't get any stronger than that. 8)
pineywoods
Quote from: Peter Drouin on April 05, 2018, 06:36:25 AM
Yeah, plenty strong, but the real advantage is weight. Just set them in place, no need for fastening. An unstable wheel chair ramp is a disaster waiting to happen..
Peter Drouin
Snow, ::)
Got it cleaned off and went well.
A little to do on the end and board it up.  8) 8)
Bruno of NH
47sawdust
By Godfrey the metal is even parallel to the rake,how do you do that? ;D
Mick
Peter Drouin
Quote from: 47sawdust on April 09, 2018, 06:26:46 AM
Lucky  :D :D ;)
  Or just tilt the rake. :D :D
  Sort of like the guy with about 6" of excess length on his belt. Lady came by and complimenting him for losing weight then walked on her way. Guy's buddy said "I did not know you had lost weight." Man replied "I didn't, I just got a bigger belt."
Oliver05262
47, probably 3-4-5 before the first sheet went on. That and making sure the diagonals were equal.
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
Peter Drouin
Just pull a line from one end to the other, Line up the bottom of the tin with it.
Peter Drouin
This is my third mud season ::)
Be nice when I dry up.
Peter Drouin
And a new sharpener.
But not all is good, My well is filling up with sediment from over the years.
so I have a 12,000.00 fix. ::)
Bruno of NH
Bummer on the well  >:(
I have had enough mud seasons for the year.
Bruno of NH
I forgot
Nice pointer
I will try to stop in this week to talk about the Northern Project
I have some bands being sharpened and a new band to try out.
I'm going to cut some old mill beams for a customer.
Yes,too bad on the well. I had one put in about 18 years ago,140 feet down,less then $5000. Bet it would be more now. :o
4x4American
You think you got a mud problem, let me take a pic of my yard holy cow is it bad!
Boy, back in my day..
PAmizerman
I wish my yard was as dry as Peters.
It's getting there. It's supposed to be nice here most of next week. It should dry things up nicely. Hopefully I'll be able to get some logs in
WM bms250 sharpener
WM bmt250 setter
4x4American
Really?  I heard rain then nice then rain then nice
PAmizerman
I just checked the weather channel app.
It says no rain here till Friday.
And you know they are always right :D
WM bms250 sharpener
WM bmt250 setter
Bruno of NH
Rained most of Sunday at my place and is raining this morning.
I hear they got snow in the north country of By and Nh
4x4American
