A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
Peter Drouin
I'm out of room too.  I like the no booger thing.
My clamp has fangs.  ;D
PAmizerman
I already have a blower
Hydraulics everywhere
Woodmizer edger 15hp electric
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
PAmizerman
I like the fang idea. I might have to try that
WM bms250 sharpener
WM bmt250 setter
POSTON WIDEHEAD
Quote from: PAmizerman on July 16, 2018, 09:46:35 PM
Blood Suckers!  :D
4x4American
@PAmizerman doesn't look like it's doin ya much good!!!  lol
Boy, back in my day..
PAmizerman
I'm like you 4x4. I need mo room. I'm not gonna set stuff up at my current location ( my dad's back yard). I'm gonna save my money for a couple more years and get things set up the way I want them at the new property. Believe you me I'm sick and tired of shoveling sawdust but at least I can see a light at the end of the tunnel now and finally found some ground that I can move to. In due time I'll get there. I don't want to get so far in debt that it scares me. I have the blower because the deal was too good to pass up.
Did you start out at you're current location or move there? Does being out along the road seem to help business?
WM bms250 sharpener
WM bmt250 setter
Peter Drouin
The fang thing is good as long as you move the clamp away from the cant before you lower it. The fang will rip two ½" holes in it.
Peter Drouin
Had a little trouble with the mill not going down when I hit the down switch. [ in patten mode] I would have to push two times to get the head to move sometimes. I put new up and down switch in, and that helped some.
So the today I put a dampener in on the transducer from Wood Mizer.
I talked with Wood Mizer and they think the wire might not be too good too, so a new one went in.
I tried it and it seems to work. Will know tomorrow. I all so put a new piece of plastic on to help keep the sawdust from packing around the guide wheel.
It will rub on the blade when I tighten it.
Rain here today that will help keep the dust down. 8)
Even Rocky was happy.  ;D
PAmizerman
Have you had the plastic on previously or is it a new idea? Seems like it may plug the lubemizer?
Hope the new parts fix the problem.
WM bms250 sharpener
WM bmt250 setter
Peter Drouin
Lube is ok. I do it to stop the sawdust from plugging up the guide wheel.
Lawg Dawg
Quote from: Peter Drouin on July 23, 2018, 06:52:47 AM
That's a good idea right there!  :)  I've also tinkered around with various pieces of plastic and scotch brite pad to keep the guides clean. Looks like your piece of plastic is thicker than a piece of coffee can
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Peter Drouin
A piece of a plastic bucket. I cut the whole thing up Will have 30 or 40 pieces.
Peter Drouin
A truck from Boston dropped off some 200-year-old timbers for me to cut into flooring.
This should be fun.  ::)
:D :D :D :D :D
Lawg Dawg
Oh Lorty!  Did you not order the "nailess" beams?  :snowball:
Pro Sawyer Network
Bruno of NH
PAmizerman
And you even got a full load of fun!!
You plan on just using standard double hard bands?
WM bms250 sharpener
WM bmt250 setter
Good thing that they came de-nailed :D.
4x4American
My friend does alot of resawing old barn timbers and walnut and stuff and he's always hitting metal.  He said he uses Morse M-34 bandsaw blades because they take cut through metal and keep cutting "the best".  Worth a shot maybe idk
Peter Drouin
I have boxes of used blades that will be just the thing to use. ;)
The biggest thing is when they clean the old mill it was sandblasted clean.
Think there's sand in the wood?  :D :D :D :D :D
4x4American
Quote from: Peter Drouin on August 01, 2018, 09:58:59 PM
They sandblasted the wood ???
Think they used walnut shells?
Peter Drouin
I'm not sure what they use, But I can feel the grit on them.
4x4American
Man oh man what did you get yourself into!!  lol
Nomad
     I do quite a bit of that kind of thing.  You've got your hands full.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Peter Drouin
I like the challenge. ;D  Every day is a new cut list.
SawyerTed
I'm interested in how you will remove the largest spike/bolt in the photo.  Will you remove it or as the posts above suggest, saw through them?
