Find Of The Day - What’s Your Guess?
Started by OffGrid973, March 20, 2019, 04:28:53 PM
OffGrid973
Heard the saws blazing on the way home and the offer to help avoid firewood rounds was generously accepted.  What type of wood do you think I am working with here?
Your Fellow Woodworker,
- Off Grid
Ljohnsaw
I'm guessing ash.  How about some close-up shots of the end grain?
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Old Greenhorn
Looks like maple. Run a metal detector over it and good luck.
esteadle
Dave Shepard
Southside
    Dumb guess I am sure based on NJ location but otherwise I'd think Pecan.
BenTN
I'll 6th it and say silver maple. Might luck into some ambrosia staining.
OffGrid973
Silver it is...great colors coming from the crotch and should be able to get 3 solid 2.5" slabs with all the movement shown.
Called it quits when the inclusion dulled out the 4degree in seconds as it was almost done. Resaw tomorrow to level out the last cut, luckily the slabs weigh ~80 lbs so easy to nibble the top off.
- Off Grid
