New Sawmill Chainsaw
Started by Magicman, March 25, 2019, 06:58:09 PM
It is a handy saw.  good for inside the shop or for little cuts. or awkward positions.  thanks for the video.  I use mine camping so it is quiet and not a fire threat like a gas saw.
I now have some other work plus a week's sawmilling behind me using the new MS362.  Most of the logs were 22' so I did the bucking along with Bibbying one "too big" log.  Wow, it has the power to spare plus the "decompression" valve makes starting a breeze.  I have run well over a gallon of gas through it, so it should be getting "broken in".
Crossroads
Congratulations on the new saw! I bought an 036 about 20 years ago. It was the smallest pro saw at the time and has a compression release, but I've never used it. The saw runs great and has decent power with a 28" bar.
My arthritic hand is what drove me to a new saw with the decompression valve.  ::)
Simple Jack
Sorry about your arthritic hand! Congrats on the new saw! I have a MS 290 and it's been a great saw for cut down a few small trees a year. A friend of mine wants to buy a saw and I was thinking about selling him mine and buying a new one. I was thinking about a new Still, but I don't want the m-tronic as well. I've seen a lot of great reviews on them. But I think I would just want to get one of the regular ones as well. I've never had to adjust my ms290. It's always seem to run and start great!  Fuel consumption? I don't care if they burn less fuel, I don't use all that much a year anyway. So the MS362 is the only one now that doesn't use the M-tronic? I might have to get one before they are all gone!!!
The Stihl brochure shows the MS362C (59cc) not M-Tronic and the MS362C-M that is M-Tronic, both being Professional saws.
The new MS311, also 59cc, is listed as a "Farm and Ranch" saw and has a decompression valve.  It also weighs 1.3 pounds more because no magnesium is used.  The MS311 is ~$200 less.
TreeStandHunter
We run 4 362's at work they have been great. Get used for several hours each day over last 2 seasons and have only required the bearing on the crankshaft replaces a few times each. Don't forget to check that bearing every few weeks, once they fail it will stall the saw at idle with the brake off.
In the process of building my own mill.
Are they M-Tronic?  If not I wonder about the mix being used or whether they are leaned out a bit too much?
If they are M-Tronic, then I wonder even more.  smiley_headscratch
Dave Shepard
TreeStsndHunter, are you talking about the bearing under the drive sprocket?
TreeStandHunter
OK, that makes more sense and has nothing to do with the fuel mix.  "crankshaft" threw me off.
I thought that all Stihl chainsaws were made in the USA, but this one has this sticker:
Figured that I had better take a picture quick because it will soon wear off.  ::)
TreeStandHunter
How did it run for you? They seem to rev quite a bit higher than the older style saws.
YellowHammer
I've got a some standard commercial Stihls of various sizes, and an one M-Tronic.  The M-tronic seems to have more "snap", more response, and I like it.  Never had any trouble with it.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Sixacresand
Good looking saw, Magicman.  I trust it is light in weight, also.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
realzed
Quote from: Magicman on April 15, 2019, 09:03:15 PM
I thought that all Stihl chainsaws were made in the USA, but this one as this sticker:
Pretty sure all of the Professional Stihl models are made in Germany!
farmfromkansas
If I had a battery powered saw, it would run out of power just before I got a tree cut through, and then would have to go plug the battery in and come back and find the tree fallen in the wrong direction. Hate to leave a tree standing, partially cut off.
