10hp deisel vs 15hp gas
Started by Bruno of NH, April 15, 2019, 08:06:06 AM
Bruno of NH
I'm getting an edger
Would a 10hp deisel have enough power to one it ?
I have a 13hp Honda gas
Southside
Do you have the torque /rpm info for both to compare?
DARRELL1972
Like Southside said you need to compare spec's. But my eg100 is a 13hp gas. I'm pleased with its performance.
95lt40hd
74 8k windham forklift
2018 eg100
Bruno of NH
Honda gas 13hp
3,600 rpm
19.5 ft.lbs. @ 2,500
Yarnmar clone 10hp
10hp @ 3,600 rpm
8.6 go @ 3,000 rpm
20 ft.lbs. @ 1,500
Your thoughts
Southside
I don't see a gain. What RPM does the edger want?
Bruno of NH
Southside it's the same as yours
I have the 13hp Honda it came off my mill
Southside
Then unless you own the diesel I would put the Honda on, actually even if I owned both I would put the Honda on, that's his standard engine anyway so it will be fine, down the road you can always upgrade.  I have a 25 HP on mine, but you don't need that much, I did that because my 35 has the same engine and I didn't have an engine sitting around.
Hackeldam Wood Products
Honda engines are bullet proof and start well in cold weather.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
