Need help
Started by JMG, April 15, 2019, 06:39:19 PM
JMG
Can someone tell me where to order cam for cat claw sharpener to sharpen wood mixer blades?
JMG🚜
kelLOGg
Cook Saw doesn't advertise it but I bet they sell it.
Banjo picker
If the tooth spacing is right, after about you sharpen it about 3 times it will be the shape of whatever cam you have.  First time just hit the edge of the tooth, next time get a little more and by the third pass clean out the gullet.  I started out with 3 cams that were 7/8 and one that was one inch.  I don't plan on ever buying anymore no matter what bands I come by.  Thats what works for me.  Banjo
YellowHammer
I bought a WM profile cam from Cooks, but it wasn't an exact match.  I had to spend time grinding it to match.  After that, I just hand ground Cooks cams to match all the WM profiles.  It's pretty easy.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
JMG
Thanks for the advice.ill scratch my head on this and then decide
JMG🚜
jaygtree
check with 'cutting edge'.
i thought i was wrong once but i wasn't.   atv, log arch, chainsaw and ez boardwalk jr.
LeeB
Member cutting edge is a good choice. You can also get it from WM. It will fit the cooks sharpener just fine.
