Tree ID - are these white walnut / butternut logs?
Started by stanmillnc, April 30, 2019, 04:57:31 PM
stanmillnc
Got a lead on huge "black walnut" logs today, so I dropped what I was doing and raced down to the site being cleared before they were chipped up. They are huge - 38" diameter at the stump and one has a nice crotch, so it was worth picking up, but looks to me like these are white walnut / butternut. These two are the same species, right? Bark on these seems a less deeply furrowed and more gray than brown than I've seen on black walnut. Also, seems like less dark heartwood and more sapwood than I normally see with black walnut. Can someone please confirm? Thanks!
Don P
Quite likely, this was one we got a week or so ago, nice score!
A butternut crotch end table from a year or two ago.
KEC
I don't know what they are, but I don't believe it's Butternut. Butternut has gray bark and the ends of the logs don't look right.
I believe that it is hickory.  Many people confuse hickory nuts with walnuts.
stanmillnc
Not hickory for sure. I've cut and milled all types of hickory and this isn't nearly as hard and looks very different. It is not dense like black walnut either.....no nuts lying around unfortunately.
Don P
It is a good bit less dense than black. I pick up the same walnut smells while milling it, not as strong but still walnut.
OK.  Next option is elm.  Looking closely at the end grain, are the latewood pores arranged in wavy bands?
Don P
We were sawing today and something else hit me in the face :D
The inner bark of a butternut is a pretty bright yellow. It's also slipping now.  The bark was used during the civil war to dye the uniforms of some southern troops a brown-yellow which is where the term "butternuts" came from.
Edit: From this USFPL link, if you use iron as a mordant with butternut bark dye you get a grey uniform, that makes more sense.
https://www.fs.fed.us/wildflowers/ethnobotany/dyes.shtml
stanmillnc
Here she is opened up - looks like butternut to me!
Don P
The color is right, more sapwood than I'm used to but every tree is an individual. Butternut is very often a cross between Japanese heartnut, of which there are several, and our butternut, the cross is a buart. Our natives are in decline from an Asian canker fungi that the crosses are often able to survive. It's apparently kind of new to the dendro guys and gives them fits trying to save pure strains, the two freely interbreed.  I always have trouble on a screen vs being there. Another clue, the pith is just like a black walnut, that loose open pith. I messed up on one set of cuts yesterday and made a group of quartersawnish cuts, butternut is much more handsome in flatsawn orientation.
After that recollection on it being a dye yesterday I was googling last night and confirmed that is was a confederate dyestuff, shot off an email this morning to the lady that runs the local living history museum, makes period clothing and is part of a reenactors group. She has made and used the dye and is coming after some bark.
moodnacreek
So there is and was butter nut down south. That is not what I would have expected. It has become rare here in s. n.y. and I have only sawn a few in 35 years but up north near the border you can find big ones where they have no black walnut. It is much colder up there with shorter summers.
Banjo picker
 There is at least one in Mississippi.  I planted about 30 and this is the lone survivor.  Several others came up but died shortly there after.  @Dodgy Loner sent me the nuts.  This one is several years older now, probably 16 foot tall or so.  Hope it makes it.  Banjo
I am not convinced that it is not hickory. That is exactly what hickory is supposed to look like.
moodnacreek
stanmillnc
Yes, this wood is soft; certainly not hickory - I've cut a lot of hickory and its very hard, not comparable whatsoever with this wood. I agree that the grain pattern is similar to some hickory however.
Hewer of Wood
Well if it's not hickory then maybe a type of elm? Or possibly a soft maple? Pretty sure it's not Butternut though.
1997 Timber Harvester 1967 Pettibone Super 8 and too much sawdust. Joshua 9:21
KEC
I am puzzeled enough by this that I'll try to go behind the house and get a photo of a butternut and put it on here. I don't see butternut  here.
KEC
A Butternut Tree in Southern Onondaga County, N.Y.
moodnacreek
That's butternut, related to b. walnut which is related to hickory.
Don P
stavebuyer
The logs in question look.like elm and nothing like butternut. I have seen,
In the original post I would have to say no to butternut. The bark isn't right and neither is the wood. I have never seen all them grain patterns in butternut nor wide sapwood. Sapwood is very thin on butternut, up here anyway. And when you saw the wood the surface is a bit fuzzy or raised grain like with basswood. Wood has no characteristic odour. I know when I have handled walnut and butternut, the butternut had no smell but the walnut did have an odour. The wood of butternut is chestnut brown and a little bit of a pinkish hue sometimes.
Quote from: WDH on May 01, 2019, 07:49:20 AM
Look for the wavy bands..........
