My new lights
Started by Percy, November 01, 2019, 09:32:07 AM
Percy
I bought an 8 pack of led shop lights from Princess Auto...29.95 a light......I should have bought about 20....these were a good deal and were on sale....as Inspector Closeau said in the Pink Panther..."Not anymore"...Regardless, they work really well....Now I can work more stupid length shifts than I am right now.... :D :D :D
highleadtimber16
I got pretty well the same lights from costco. I put 6 of them above my mill. I can't work without them now.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
Dakota
Dave Rinker
Resonator
If you've ever had to work under dim flickering fluorescent bulbs on a sub-zero morning, then you will truly appreciate LED's. smiley_sidelightbulb
Southside
Funny timing. I put in 70,500 lumens worth of LED's just this past week.
terrifictimbersllc
Close Encounters of the orange kind.
rjwoelk
I have similar ones in my shop we just installed. Lots of light.
dustintheblood
Literally walked in from the shop as we finished installing new LED's on the forwarding trailer.  Four-up bar with 120 degrees total, mounted at the base of the boom so it's always pointed where my eyes are.
Mill's next to get the sunlight at night treatment ... off to Princess Auto this evening after a timmies stop.
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
Nebraska
You mean there's a better way than holding my cell phone on flashlight in  my teeth to read the scale and  set my last two cuts in a cant I didn't get finished before dark..... I wish I was kidding.. ::)
Southside
Been there, done that. I find it works better if you clip the belt clip to your shirt collar actually.
Old Greenhorn
Quote from: Nebraska on November 01, 2019, 03:20:31 PM
I thought I was the only one that did that  (I don't have a cell phone so I use a flashlight). I can't wait until I move the mill and have commercial power available for some lights. Right now I sometimes have to use a flashlight during the day if it's cloudy because the mill is under a huge tarp.
wodbutchr
Anybody installed 12V LED on the mill head, not to cut the log clamps for those who mill by night?
LT40 manual, L190 NewHolland, Homemade Log Cart "LogMob"
Andre
Timber Frarmer
Southside
Old Greenhorn
Quote from: wodbutchr on November 01, 2019, 08:47:29 PM
I think about this all the time, just have not had time to do it. I need to get a battery and get it done.
wodbutchr
Southside: Looks good.
Got more pics on how you attached it? 12V Wiring from the mill?
Has this been discussed on the forum before?
Thx
Andre
Timber Frarmer
Southside
All the wiring is in loom so a picture would not do much.  But here is a diagram.  I used the 12v + laser wire (#1207 on my mill) as a trigger source to feed into a waterproof relay, this way I can turn the lights on or off from the DCS station, and there is no significant draw onto that circuit.
The lights come in quite handy even during the day if there is a shadow or if it's overcast, one pair mounted on the back of the head and one on the front. (I only had half on them on there when I took the photo).  It completely eliminates any dark spots even from 36' away.
If you have a walk along or a Command Control model the same thing could be done just using a toggle switch rather than tying into an existing circuit for a trigger.  I didn't want to have to walk up to the mill and flip a toggle so I went the route I did.
YellowHammer
Sweet setup all of you guys. Those LED shop lights look like a lot of bright for the money.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
wodbutchr
Southside: Thanks for the info, something to chew on...
Andre
Timber Frarmer
Crusarius
I had a ton of t8 fixtures that had bad ballasts in them. I just bought the t8 LED tubes in bulk from amazon. The last batch I bought cost me $4.00 per bulb. I rewired the lights to eliminate the ballast and powered them on one end. They are so much brighter, instant on, and instant bright. Worth every bit it took to do it.
