My Weekend, or, How to Sink a Crawler.
Started by Weekend_Sawyer, January 06, 2020, 11:14:09 AM
jdonovan
Ah too used to dozers which have much more substantial tracks
Southside
I don't think triple grousers would have helped him.... :D
jdonovan
He could have dug that hole a lot faster with triple grousers, which would have given him more daylight to work on getting it unstuck. :D
chet
Lots of crawler loaders have a backhoe too. Which he could have used ta dig dat hole.  ;D  Although it might have taken longer.   :D
Sorry Jon, no mercy from this bunch.  :)
Don P
"You'll have some of that on these big jobs"
Greyman
Here's another method if you're sunk too deep for the pole or have a longer distance to go.  Works on trucks etc. also, but not tracked vehicles.    https://www.youtube.com/watch?v=d09MAs9bNpE
Greyman,
   Thanks for posting. I started to say that was pretty slick but that is how they got in the fix they were in to start with. :D It is a very useful looking solution.
randy d
Thanks for posting that was pretty slick I have chained a pole across the wheels a few times but this looks to be less dangerous . Randy
Ed_K
 He would have been better off to leave the bucket down with pressure to keep the front tires up an also stabilize the tractor better.
Ed K
moosehunter
Jon, I stuck a D6 and it looked a lot like that. Mud was top of tracks were at the same level. Father of the gal I was digging the pond showed up with his large JD backhoe and dug me out. He had to dig all the way around me then in front , I just drove out.
mh
"And the days that I keep my gratitude
Higher than my expectations
Well, I have really good days".    Ray Wylie Hubbard
scsmith42
Tom's 3638D Baker band mill
square1
Quote from: GAB on January 06, 2020, 08:44:48 PM
Quote from: Chuck White on January 06, 2020, 08:39:04 PM
That works pretty good, Lynn!
As a sidenote:  keep the chain AWAY from the valve stem!  :o
And keep the engine rpm's to the minimum possible.
GAB
And only BACK over it. Dad drove the exhaust stack on a Super M into the ground trying to drive forward doing this.
Weekend_Sawyer
We are heading up this weekend to try and retrieve the machine.
I don't know what to expect as it snowed 4 - 6" (depending on who you ask)
and will be in the 60's.
Jon
Imagine, Me a Tree Farmer.
chet
Quote from: Weekend_Sawyer on January 10, 2020, 08:37:23 AM
Jon
Sounds like yer gonna have lots more mud   :(
Raider Bill
Jon
Good luck Jon. be careful.
The First 72 years of childhood is always the hardest.
Weekend_Sawyer
My brother Chris and I had a good weekend to get the machine out.
The snow melted and the temp went up to 60!
We used block and tackle and rigged a 4 part line and using
Our neighbor Steve's 75 Hp 4wd New Holland, it came right out.
We spent Saturday afternoon helping Steve do some maintenance on his New Holland and then all day Sunday demudding the crawler, changing the engine oil and rear drive oil.
The engine oil was not compromised but it was time. 5 gallons.
The transmission oil looked fine so we didn't mess with it.
The rear end oil looked like a pink milkshake. We changed it. 15 gallons.
What I should have done was to drain the contaminated oil, refill it with diesel fuel, drain it and then put in the fresh oil. But alas I skipped the 2nd part and the fresh oil is now slightly contaminated. I'm going to run it for about 30 minutes and then change it again.
Overall, what a weekend.
Yes we and all of our equipment got real muddy.
But really, we all had a pretty good time working together.
I still have one saw log down in that bottom and it's going to stay there till we can install come culvert's and a couple loads of shale.
Meanwhile, next weekend there's a couple of blow downs at a higher elevation I can retrieve!
Jon
GAB
DPatton
Quote from: Greyman on January 08, 2020, 05:51:29 PM
I grew up farming in Southeast Nebraska, and that is not considered a stuck tractor. Although being an International maybe I over estimated it's capabilities.  :D :D :D
D & S Sawmill Services
