Valmet 546 series II Forwarder Front Axle
Started by Wrenchman, November 24, 2018, 10:41:34 AM
Wrenchman
Looking for some clarification on what Ford front axles will fit my Forwarder. Broke a right front axle shaft and housing, searching for a replacement. I was told the 5000 series to 7000 series Ford tractor rear axle housing will fit. Any info would be greatly appreciated!
mike_belben
Praise The Lord
snowstorm
i have a parts book for a 546 harvester i will look tomorrow
Wrenchman
Riwaka
Ford/ New Holland and now CaseNewHolland (CNH) change their part numbers from time to time and there are often parts numbers that do not match between paper parts manuals, official online parts manuals and third party parts manuals. (just to confuse everyone)
E9NN4012CB shows up as a 40 series tractor part?? Usual idea is to measure all the dimensions of the housings/ photograph them etc and measure up the internal parts as well.
New Holland (8340) - 6 CYL AG TRACTOR 40 SERIES (11/91-7/98) Parts Diagrams   (messicks online for 8340, rear axle etc diagram part 28 etc has different numbers in the current housing part code/ numbers showing)?          two current parts numbers?  81871490   &
81871488
Brian_Rhoad
That's too bad. I hope the search and repair will be short.
Southside
mike_belben
Praise The Lord
I JB welded the front case on my 03 Dodge 3500 transfer case. It must've developed a crack when my front driveshaft had a u-joint fail. So the jb is holding my lube in😁
Wrenchman
Found a housing and a shaft at a tractor salvage yard out of Missouri, hope to have them for the weekend.
Oliver05262
   Bootheel? They always treated us OK. Parts are as described, and I'd recommend them anytime.
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
nativewolf
Quote from: Wrenchman on November 26, 2018, 08:50:50 PM
Good deal.  Great thing is the interwebs
Liking Walnut
Wrenchman
Quote from: Oliver05262 on November 26, 2018, 10:42:47 PM
Cook Tractor Parts
David-L
Seen a lot of those housings fail. Is the rear axle housing a different beast. Glad you found the goods.
In two days from now, tomorrow will be yesterday.
Wrenchman
Yes, the rear axle is made by someone else (can't remember who), but it's not Ford.
lucshik
lucshik
Firewoodjoe
My 5550 iron mule looks the same and it shares the same parts as a ford A62 wheel loader. Can I ask how that broke?
Firewoodjoe
Wow I just noticed this thread is from 2018!
mike_belben
My forktruck has A62 axles and ive got a parts breakdown if anyone needs info on it.  Nassco in alabama may have parts.
Praise The Lord
