Finally - My Firewood Processor Converted to a Slab Saw
Started by jmur1, October 21, 2020, 02:02:00 PM
jmur1
I ran the processor as a slab saw with out the tray for some time.   Finally got the tray in place - seems to work pretty good.
Check the video below.
jmur1
Firewood Processor Converted To Slab Saw - YouTube
Easy does it
jerry sundberg
It looks a bit iffy to me, might get hit by cut offs.
Farmall  man
jmur1
Hi Jerry:
It does on occasion send some wood flying (both as a processor and a slab saw).  The enclosure window was made out of 1/2" bullet proof plastic and the sheet steel is 10 Gauge.
jmur1
Easy does it
mike_belben
Nice work.  13hp saw motor?   Does it run the hydraulics too?
Praise The Lord
jmur1
Hi Mike:
It was a 15 hp when I started out - that ran the saw and the hydraulics.  I upgraded it to a 20 hp Honda twin (and decreased the main cylinder size from 5" to 4") and found the speed to be significantly improved.  I have some other videos on my utube channel that show the new motor in action.  Although I need to make a new one that gives the thing some proper justice on a good run.  It seems every time I get the camera out I have all kinds of trouble!
If you check this video in the middle somewhere you can see the speed improvement
Homemade wood processor has a bad day. A 6" piece solid metal snapped like a twig! (6:30 minutes) - YouTube
jmur1
Easy does it
hedgerow
jmur1   Looks like the 20 HP Honda made a big difference in speed of the processor. Watch that slab wood I have a buddy that cuts a lot of it on a buzz saw and it likes to fly out sometimes. You have a nice protector with that bullet proof plastic.
jmur1
Hi Hedgerow: :D I think I still have a bump on my leg where a small log flew out at me. (before the enclosure)
I do feel a bit safer these days.  It also pays to keep the blade sharp.
Thanks for watching!
jmur1
Easy does it
moodnacreek
A peg tooth or type M saw will work better than a saw with hooked teeth. The problem here is that it cannot be carbide as far as I know. The saw I am talking about can be mounted either way as the teeth are straight.
jmur1
Hi moodnacreek:
That would be an interesting sawblade!
jmur1
Easy does it
