Square inch pricing
Started by WV Sawmiller, March 17, 2021, 07:05:05 PM
This is a raised planter I made from scrap/low grade walnut with a lot of sapwood and such that am using as a display for the cut up/trimmed out walnut boards. It is about 4' long X 2' wide with 1' high sides and 3' tall legs. I need to get something with taller sides for a dozen or so boards on the left side that are about 3' long or longer.
This is a box/tray I built for the short stuff. I have more short stuff than it will hold but I see I can take some of the longer boards here and transfer them to the other box and hopefully they will all fit then, especially once I remove the longer boards. I will run a little bit of this through the planer, price accordingly and see which sell the best.
   I see I have enough scrap walnut left to make another planter box or two so I guess that is another project to add to the list.
