Big Timber
Started by Rhodemont, July 12, 2021, 09:45:46 AM
Rhodemont
I watched an episode on Netflix of a sawmill in Vancouver that has a "claim" to take cedar of the side of a remote mountain and move it to their mill and sell logs to another.  The side of the mountain has been clear and is a total mess to pull the logs up and off. Looks really dangerous  Why would they not remove the logs as they cut?  Or, a lot of the stump diameters look bigger than the logs so were the big ones already pulled off and they are going after the leftovers?
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Old Greenhorn
I don't work big jobs in the PNW like this at all, so take this with a grain of salt. I'm sure the big cutters here will chime in over time.
Access to these logs is from above. It is safest and easiest for yarding to fell the trees downhill and pull the butts uphill. They start at the bottom so that once they get into it and work their way uphill there is room for the trees to fall and not hang or break. With most of the standing trees on the uphill side, the yarder can't pull the logs through those standing trees, so they have to get them all down first. Also, think of how hard it would be to get that mainline up in the air with all those standing stems. Lastly, falling and yarding are two different things with two different skill sets and they cannot take place at the same time. Falling trees while yarding goes on, to clear them is a very dangerous thing to do. I wouldn't want to be a hook tender with falling going on around me. These are just my educated guesses. I am sure the show is not giving the full details because if you look at the logs on the trucks as they head out to the mill, they look a lot different than the busted up stuff they show getting yarded up the hill.
There is another thread on this show you might want to check out:
https://forestryforum.com/board/index.php?topic=115918.msg1834308;topicseen#msg1834308
sawguy21
Tom has covered it well. The fallers go in ahead of time then the riggers come in with the yarder or helicopter to recover the timber. It is hauled to roadside for processing then trucked, boomed, or barged to the mill. Often they will first go to a sort yard where the loads are broken down according to size and species, different mills have different requirements.
As you noted it is hard dangerous work. The ground crew or hookers as we called them are all in their late teens and 20's, by thirty they are either busted up too bad to carry on in that work or dead. I worked in support with helilogging crews for five years, it was a real eye opener.
Those stumps are from previous harvests, you were seeing probably the third or maybe the fourth. It is a coastal rainforest and the rate of growth is phenominal.
Skeans1
Quote from: Rhodemont on July 12, 2021, 09:45:46 AM
When planning out a high lead job the cutting start at the bottom working your way up the hill for less potential of a log to go rolling on you. To how the direction of the cutting is done there's two schools of thought straight down the hill which makes a mess of stuff, or quarter across the hill side which is normally safer for everyone involved if it's bucked lengths. They do cut well yarding is going but it's a much slower process then yarding is so it's one of the reasons most if not all cutting is completed before any yarding is started. As far as stumps go you're in reprod timber vs old growth which in someways is more dangerous then the big old girls were.
Quote from: sawguy21 on July 12, 2021, 11:20:43 AMAs you noted it is hard dangerous work. The ground crew or hookers as we called them are all in their late teens and 20's, by thirty they are either busted up too bad to carry on in that work or dead. I worked in support with helilogging crews for five years, it was a real eye opener
Local companies are developing remote controlled grapples to eliminate the need to have people on the ground when playing pickup sticks.
The carriage has it's own hydraulic power pack, and remote cameras so the operator can see and control what's going on down there, steer the grapple to a log and snag it.
The felling on the hillside isn't especially dangerous because the trees are being dropped downhill and falling away from the logger. Working in that jumbled mess is what gets dangerous, so there is a push to remove that.
Should pay for itself in reduced accident insurance alone, and a misspent youth playing the Crane games at the amusement arcade is now a valuable job skill. ;D
sawguy21
We experimented with grapples but it was not as productive as men on the ground. The logs were not laid out neatly, often jumbled like pick up sticks at the bottom of the slope, and gave the pilot another task to take his mind off flying.
donbj
I hooked chokers on a yarding show in the late 70's. I was 23. You had to be on your game for sure as a good part of the time the operator couldn't see you or know where you are. We wore radio signal belts that sounded the horn for the operator. Stop, haul in, haul back, tightline etc.
The tightline was where you better keep your eyes open and yourself well out of the way while getting mainline back on track or jumping to the next block. Actually enjoyed it and we set some production records on top of it all.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Yeah, I can see more problems with helicopter operation. Having to fly AND play Pick-Up-Sticks at the same time would be "tricky".
This is a carriage on a fairly conventional cable yarder. They are experimenting with VR headsets view from the cameras on the carriage, so the operator is "right there" looking at the grapple,
It might be slower than a team doing hookups, but it's a heck of lot safer, and a cable yarder cost's less per hour than a heavy lift chopper.
Falcon Grapple Claw 2019 - YouTube
teakwood
Quote from: Old Greenhorn on July 12, 2021, 10:21:45 AMI am sure the show is not giving the full details because if you look at the logs on the trucks as they head out to the mill, they look a lot different than the busted up stuff they show getting yarded up the hill.
That is exactly what i thought also. loved the show, couldn't stop watching, sadly just one season. cool operation he has going one, although i would hate to repair every machine every time you use them, it seems they loose half of the day with fixing that old crap equipment.
what really astoniged me is how weak that cedar wood is, a 3 foot log just snapped right of where the choker is just because it hits a rock, snapped like a tooth stick :o
Rhodemont
Watched a couple more episodes.  They must dramatize every little thing they can to make it exciting with all the breakdowns to overcome in order to get the "200" loads out.  Beyond that as you guys have pointed out...if being a hooker is anything like they are showing it must be a short life.
donbj
Those reality shows dramatize everything big time. We just watched our backs and the guys we worked with and did our jobs. I find it hard to watch some of those shows.
mike_belben
I shun television as much as possible.  On the rare occasion i am in the vacinity of some "work show" where the stuff is hitting the fan and stupid things are breaking at every commercial break on a 4 minute rotation 3 cycles long to build suspense before they play the whole segment..  Next thing you know the sergeant in me is chewing a bunch of boots up one side down the other. I will get terribly angry at the stupidity of it all and that theyre brainwashing the young suburban teenage viewers into thinking this is normal on a jobsite when it just isnt.
Next thing you know im wide eyed, veins popping,  yelling at the stupid show.   all you idiots are fired.. where the hell did you learn to be a man.. at the circus!? What is wrong with you?!  Whatd you think was gonna happen stupid!? get out of here and bring me a crew of teenagers that will listen and use half a brain for gods sake.
Yeah im pretty bad.  No tv for this guy.  Especially not "reality" television.
Praise The Lord
HemlockKing
Quote from: mike_belben on July 13, 2021, 03:23:12 PM
I'm not one for television, I did use to love the show mighty machines, how it's made, mythbusters and dirty jobs. Haven't seen any of those in a long time. Discovery channel use to have some cool and inspiring stuff playing on it each day.
A1
Old Greenhorn
Well first, this isn't TV, it's netflix. I too hate those shows where they simply everything down into a crisis of the moment and create artificial drama. I didn't get much of that from this show at all. It's the reason I enjoyed it. As a reasonably intelligent and experienced adult I found this to be quite watchable. It is the same reason I could not watch axmen which was also working guys, but in my mind they made them out to look like incompetent baboons working without due regard for anything but money.
HemlockKing
Quote from: Old Greenhorn on July 13, 2021, 05:16:12 PM
Netflix and YouTube are basically the new television lol a tradesman drama series that comes to mind for me was ice road truckers. What a unprofessional clown show they displayed it as.
A1
tawilson
Quote from: HemlockKing on July 13, 2021, 05:41:07 PM
The first season or two were better. They started out focusing on the ice trips themselves as I recall.
2017 LT40HDG35 WIDE
BMS250 and BMT250 sharpener/setter
Woodmaster 725
mike_belben
If you wanna live a clown show just get a CDL and a CB radio.   The road can be a total zoo at times.  Very unforgiving.
Praise The Lord
HemlockKing
Quote from: mike_belben on July 13, 2021, 06:24:40 PM
I almost went that route. Did the useless schooling too(I did learn a little but big rip off), I was 19, so I was young and dumb and got suckered in.I found a job in a  Fab shop shortly after and I enjoyed that more so forgot about the trucking. They call it a class 1 license here
A1
Ed_K
 I never understood why OSHA never came and shut them down  >:(.
Ed K
Satamax
Pretty much the same, but i yell even more at the translators, who know zilch about the job they're doing the translation about. I have seen fenders called culasse (head) or block and tackle, called chaĆ®ne et bloc! (chain and block)
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
mike_belben
Hey that could be a good retirement gig for you.  Youve got us available for any stumpers that may arise. And youre english is pretty dang good too.
Praise The Lord
hacknchop
Trouble with reality shows is they ain't real. Rhonda has caught me watching me some Timber related or restoration show with no volume "turn it up she says so you can hear what their saying" i don't want or need to hear what they are saying  I just enjoy the build or the scenery. Most of those shows are geared towards entertainment not even trying to educate,so take them for what they are(entertainment) and if your not entertained shut it off go do something else.
Often wrong never indoubt
Iwawoodwork
Oregon OSHA did cite the "Axe men" way back when it was first filming in Oregon. I was working for them at the time. (1990-2010)  The show was used as evidence of their safety violations.
I just watched my first "Big timber" last evening and if a person has worked in the NW logging industry (1969-1990) there definitely some parts that are less than real but it was still entertaining and great scenery, Personally I liked the old auction equipment he had and used.
For a small operator he has quit a variety of machinery from sawmill, road building and logging.
