Portable Milling Production and Efficiency
Started by Willski55811, July 12, 2021, 04:48:14 PM
Southside
If you do a search for "Hydraulics Anywhere" on here you will find a couple of threads. Basically hooking up a second battery to the hydraulic box will give you the ability to run your hydraulics with the head off the contact strip. It's a real time saving modification and easy to do.
   Another thing to remember about your hydraulics is if you are using them while the head is moving along the power strip you are causing arcing and will get burned/dead spots and when you have the head resting on one of these dead spots, your hydraulics won't work. (Don't ask me how I found this out ::)). You either have to sand off the dead spot or move the head forward or back to make a live connection to continue use of your hydraulics.
Quote from: WV Sawmiller on July 14, 2021, 02:01:31 PM
Robert,
And if they are wearing a Roll Tide or UGA bulldog shirt I don't even disconnect. :D
Now, I like that  ;D.
YellowHammer
Quote from: WDH on July 14, 2021, 05:28:31 PM
Robert,
Disconnect?  I should say not!  If a sawyer shows up out here wearing a War Eagle shirt, he'd be well advised to keep the engine running in case the neighbors find out and come rolling up!!
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Stephen1
Quote from: YellowHammer on July 14, 2021, 01:51:36 PM
Quote from: WV Sawmiller on July 14, 2021, 01:43:46 PMI like to be able to back up a few feet, hook up and drive away any time I want.
THAT is a good tip.   smiley_thumbsup smiley_thumbsup smiley_thumbsup
I do that also, now I know why. ;D
Willski55811
Yeah I definitely want to be able to hook up and go at the end of the day so I have made sure to leave myself a path of escape! As far as direction of waste and finished, I have tried both but now that you say finished off the front that does seem to make more sense.
As for operating the hydraulics while the head is moving, that is good to know.
